In version 3.0.0 could load the shape, but with version 3.0.2 does not load the map. We have already started a new project on a PC clean and error continues. Is there a different procedure of version 3.0.0?
Problems with Web Edition versiion 3.0.2
Helio,
The method for loading the map in 3.0.2 is the same as for 3.0.0. Are you receiving an exception?
Ryan,
Does not happen any exception or error message. Not only shows the map.
I'm using this code:
using
System;
using
System.Configuration;
using
System.Data;
using
System.Linq;
using
System.Web;
using
System.Web.Security;
using
System.Web.UI;
using
System.Web.UI.HtmlControls;
using
System.Web.UI.WebControls;
using
System.Web.UI.WebControls.WebParts;
using
System.Xml.Linq;
using
ThinkGeo.MapSuite.Core;
using
ThinkGeo.MapSuite.WebEdition;
public
Map1.MapUnit =
municipio.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle =
municipio.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel =
Map1.StaticLayers.Add(municipio);
Map1.CurrentExtent =
Map1.BackgroundFillBrush =
partial class _Default : System.Web.UI.Page protected void Page_Load(object sender, EventArgs e)
if (!IsPostBack)GeographyUnit.Meter;ShapeFileLayer municipio = new ShapeFileLayer(@"C:\inetpub\wwwroot\prototipo\Mapas\MUNICIPIO.shp", ShapeFileReadWriteMode.ReadOnly);AreaStyles.Country1;ApplyUntilZoomLevel.Level20;new RectangleShape(0, 100000, 100000, 0);new GeoSolidBrush(GeoColor.StandardColors.LightSteelBlue);
Helio,
Are you loading a shapefile that is in the Geodetic projection or some other projection?
ThinkGeo Support
Ryan
The shape has the following settings:
Projected Coordinate System: SAD_1969_UTM_Zone_23S
Projection: Transverse_Mercator
False_Easting: 500000,00000000
False_Northing: 10000000,00000000
Central_Meridian: -45,00000000
Scale_Factor: 0,99960000
Latitude_Of_Origin: 0,00000000
Linear Unit: Meter
Geographic Coordinate System: GCS_South_American_1969
Datum: D_South_American_1969
Prime Meridian: Greenwich
Angular Unit: Degree
Attached follows the code and the shape.
Please the file shape.txt, rename to shape.rar.
37-Code.txt (1.22 KB)
38-shape.txt (26.3 KB)
Helio,
There is a known issue where shapefiles in a projection other than Geodetic cannot be displayed by Map Suite 3.0 unless the projection of the shapefile is specified in code.
Using the following code the shapefile will load because we are specifiying the projection. Here we are loading a shapefile with an ESPG of 27700:
if (!Page.IsPostBack)
Map1.BackgroundFillBrush = new GeoSolidBrush(GeoColor.FromHtml("#B3C6D4"));
ShapeFileLayer worldLayer = new ShapeFileLayer(MapPath(@"/App_Data/testshapfile.shp"));
// you can set projection like this,
worldLayer.FeatureSource.Projection = new Proj4Projection(27700, 27700);
worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.GetSimpleAreaStyle(GeoColor.FromArgb(255, 243, 239, 228), GeoColor.FromArgb(255, 218, 193, 163), 1);
Map1.StaticLayers.Add(worldLayer);
My problem is the same and I do it in VB but nonetheless it does not load one *.SHP my code is the following one
It does not go out alone mistake loads the page but it does not show me the map.
You can help me?
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
If (Not Page.IsPostBack) Then
Map1.BackgroundFillBrush = New GeoSolidBrush(GeoColor.FromHtml("#B3C6D4"))
Map1.CurrentExtent = New RectangleShape(-114.34, 75.27, 108.79, -70.23)
Map1.MapUnit = GeographyUnit.DecimalDegree
Dim mapanavarra As ShapeFileLayer
mapanavarra = New ShapeFileLayer(“c:\navarra\Navarra.shp”)
'you can set projection like this,
'Map1.FeatureSource.Projection = New Proj4Projection(27700, 27700)
mapanavarra.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.GetSimpleAreaStyle(GeoColor.FromArgb(255,243, 239, 228), GeoColor.FromArgb(255, 218, 193, 163), 1)
mapanavarra.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
Map1.StaticLayers.Add(“MapaNavarra”, mapanavarra)
Map1.ScaleLine.Enabled = True
Map1.PanZoomBar.Enabled = True
Map1.MousePosition.Enabled = True
Map1.LayerSwitcher.Enabled = True
Map1.Overview.Enabled = True
End If
End Sub
And as exchange this line in vb
It does not show me the shp (map)
my code is :
(Not Page.IsPostBack) Then New GeoSolidBrush(GeoColor.FromHtml("#B3C6D4"))New RectangleShape(-114.34, 75.27, 108.79, -70.23)Dim mapanavarra As ShapeFileLayerNew ShapeFileLayer("c:\navarra\Navarra.shp")'you can set projection like this,
mapanavarra.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.GetSimpleAreaStyle(GeoColor.FromArgb(255, 243, 239, 228), GeoColor.FromArgb(255, 218, 193, 163), 1)
mapanavarra.DrawingQuality = DrawingQuality.HighQuality
"MapaNavarra", mapanavarra)'Map1.DynamicLayers.Add("MapaNavarra", mapanavarra)
True
True
True
True
True
End If
wait for your help
Map1.MapUnit = GeographyUnit.Meter
mapanavarra =
If
Ryan
I added the following code:
________________________
ShapeFileLayer
municipio = new ShapeFileLayer(@"C:\inetpub\wwwroot\prototipo\Mapas\municipio.shp", ShapeFileReadWriteMode.ReadOnly);new Proj4Projection(29183, 29183);
___________________________
and now load the map without problems.
municipio.FeatureSource.Projection =
Helio,
Glad it is working for you and thanks for sharing your code.
ThinkGeo Support
