Proj4Extensionx64.dll exception
I got another exception in RC1 307, "StackOverflowException was unhandled", "An unhandled exception of type 'System.StackOverflowException' occured in Proj4Extensionx64.dll, make sure you do not have an infinite loop or infinite recursion.
Here is the scenario:
I opened a PostgreFeatureLayer, and do a spatial query in the winformMap1.TrackOverlay.TrackEnded event handler, so draw a circle, then select the features intersecting with the circle, keep doing this for a few times, then got this exception.
Rose
Rose,
 We are setting up the test environment and will have the X64 bit test tomorrow. We will let you know if we have anything.
