Projection Vn 2000 display in map?
Hi all!
I'm a Vietnamese. In Viet Nam, build maps have to use VN 2000 projection.
But i don't know how to thinkgeo support it? Can you help me?
Nguyen,
 I would point you out to spatialreference.org web site that has all the projections used by Map Suite. I did a search for Vietnam and found the projection you were talking about. Each projection has a code such as the EPSG code. spatialreference.org/ref/epsg/4756/
 Now on how to use projection in code in Map Suite, you can look under the category "Projection" of the How Do I Samples. You can look at the wiki section on projection 184.73.226.83/wiki/Map_Suite_Deskto...Projection. You can also look at some samples on projection in the Code Community wiki.thinkgeo.com/wiki/Map_Suite_De...on_Samples
Thank you.
