I am using different type of projections. Everything works fine. One doubt is - on map where projection lat lon parameter ends till lat lon that map coming correct. As shown in first image.
After the given range of latitudes it will get distorted as shown in image2.
Also when zoom out also whole map get distorted as shown in image3.
I think this is expected behavior when applying some projections. My doubt is - I have plotted one line from -90 27,-120 27 lon lat. Which is out of projection lat lon parameters. So on distorted area line is joining from front. Because -90 is coming on left side of map and -120 is coming on right side. Images are attached below.
Please guide to overcome this issue.
Goral
Projection
Hi Goral,
Would you please share some codes here? I was a bit confused with the coordinates -90 27,-120 27 mentioned here, it’s lon/lat? looking forward to your further information.
