Province shapefile background color change from database table
First of all i wants to thanks to you from your help i done my 80% job now i have another issue which i wants to resolved.
i am going to tell my scenario which is the following
1 i have province shapefile display on my map
2 i have database table which have the following columns
province_name,active
in province name should like name like my shape file. and in active column data will be yes or no
3 i wants to match my shapefile province name with my table province_name and if in active column is there is yes than color that province
for example
there is a province called ‘kabul’ if in my table column of active if value is yes than kabul all background color change. can you help me in this how should i done this how to match my database table column with my shapefile column ?
so far i done like this.
ShapeFileFeatureLayer province = new ShapeFileFeatureLayer(MapPath("~/Layer/afghanistanprovince.shp"));
       province.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;
        province.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = new TextStyle(“Prov_Name”, new GeoFont(“Verdana”, 9),
          new GeoSolidBrush(GeoColor.StandardColors.Blue));
            province.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.RequiredColumnNames.Add(“Prov_Name”);
          province.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = new
AreaStyle(new GeoPen(new GeoColor(255, GeoColor.SimpleColors.Blue)));
        province.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
        province.DrawingFeatures += newLayer_DrawingFeatures;
            Map1.StaticOverlay.Layers.Add(“Province”, province);
        void newLayer_DrawingFeatures(object sender, DrawingFeaturesEventArgs e)
            ZoomLevel zoomlevel = e.DrawingZoomLevel;
            foreach (Feature feature in e.FeaturesToDraw)
                string provinceName = feature.ColumnValues[“Prov_Name”];
                if (provinceName == “Kabul”)
                        zoomlevel.DefaultAreaStyle = new AreaStyle(new GeoPen(new GeoColor(255, GeoColor.SimpleColors.Yellow)));
                    zoomlevel.ApplyUntilZoomLevel=ApplyUntilZoomLevel.Level20;
                else
                    zoomlevel.DefaultAreaStyle = new AreaStyle(new GeoPen(new GeoColor(255, GeoColor.SimpleColors.Red)));
                    zoomlevel.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
why my    if (provinceName == “Kabul”) this condition run multiple time i
have only one kabul province in my shape file also my shapefile
defaultareastyle display of else part like this
else
                    why is that please tell me reason thanks
Hi Raja,
 Please see my reply in other topic.
 thinkgeo.com/forums/tabid/143/aft/12879/Default.aspx
