First of all i wants to thanks to you from your help i done my 80% job now i have another issue which i wants to resolved.
i am going to tell my scenario which is the following
1 i have province shapefile display on my map
2 i have database table which have the following columns
province_name,active
in province name should like name like my shape file. and in active column data will be yes or no
3 i wants to match my shapefile province name with my table province_name and if in active column is there is yes than color that province
for example
there is a province called ‘kabul’ if in my table column of active if value is yes than kabul all background color change. can you help me in this how should i done this how to match my database table column with my shapefile column ?
Province shapefile color change from database table
Hi Jaja,
I think the DrawingFeatures event may helps on your case, some codes as following:
ShapeFileFeatureLayer newLayer = new ShapeFileFeatureLayer();newLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;newLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.RequiredColumnNames.Add(“Province_Name”);newLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.RequiredColumnNames.Add(“active”);newLayer.DrawingFeatures += newLayer_DrawingFeatures;Map1.CurrentExtent = new RectangleShape(-155.733, 95.60, 104.42, -81.9);WorldMapKitWmsWpfOverlay worldOverlay = new WorldMapKitWmsWpfOverlay();Map1.Overlays.Add(“WMK”, worldOverlay);Map1.Refresh();}
void newLayer_DrawingFeatures(object sender, DrawingFeaturesEventArgs e){foreach (Feature feature in e.FeaturesToDraw){string provinceName = feature.ColumnValues[“Province_Name”];// Do the search in databaseif (true){// change the background color by zoomlevelZoomLevel zoomlevel = e.DrawingZoomLevel;zoomlevel.DefaultAreaStyle = …}}}
In above codes, don’t forget to add the highlight lines codes, as adding the two required column will make them include in the DrawingFeatures feature’s column.
Please let us know if any questions.
hi i did this with the following code
ShapeFileFeatureLayer province = new ShapeFileFeatureLayer(MapPath("~/Layer/afghanistanprovince.shp"));
province.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.City1;
province.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = new TextStyle("Prov_Name", new GeoFont("Verdana", 9),
new GeoSolidBrush(GeoColor.StandardColors.Blue));
province.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.RequiredColumnNames.Add("Prov_Name");
province.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = new AreaStyle(new GeoPen(new GeoColor(255, GeoColor.SimpleColors.Blue)));
// province.ZoomLevelSet.ZoomLevel01.DefaultTextStyle.HaloPen = new GeoPen(GeoColor.StandardColors.White, 2);
province.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
Map1.StaticOverlay.Layers.Add("Province", province);
province.DrawingFeatures += newLayer_DrawingFeatures;
string provinceName = feature.ColumnValues["Prov_Name"];
if (provinceName == "Kabul")
Zoom Level zoom level = e. DrawingZoomLevel;
zoomlevel.DefaultAreaStyle = new AreaStyle(AreaStyles.Country1.OutlinePen,
new GeoSolidBrush(GeoColor.SimpleColors.Yellow));
// zoomlevel.DefaultAreaStyle = "";
//else
// ZoomLevel zoomlevel = e.DrawingZoomLevel;
// zoomlevel.DefaultAreaStyle = new AreaStyle(new GeoPen(new GeoColor(255, GeoColor.SimpleColors.Blue)));
but i have some issue with this
this condition is running more than one time and also my all province color is yellow i dont know why can you please modify my code. thanks
hi i try this
province.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;
zoomlevel.DefaultAreaStyle = new AreaStyle(new GeoPen(new GeoColor(255, GeoColor.SimpleColors.Yellow)));
zoomlevel.ApplyUntilZoomLevel=ApplyUntilZoomLevel.Level20;
else
zoomlevel.DefaultAreaStyle = new AreaStyle(new GeoPen(new GeoColor(255, GeoColor.SimpleColors.Red)));
zoomlevel.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
why my if (provinceName == "Kabul") this condition run multiple time i have only one kabul province in my shape file also my shapefile defaultareastyle display of else part like this
else
why is that please tell me reason thanks
basically i wants to color province with different color for example
province a background should display yellow
and province b background should display green
can i do this ?
Hi Raja,
As below is a simple sample from your code which can be run in our HowDoISample, wish that’s helpful.
using System;
using ThinkGeo.MapSuite.Core;
using ThinkGeo.MapSuite.WebEdition;
namespace CSSamples.Samples
public partial class DisplayASimpleMap : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
if (!Page.IsPostBack)
Map1.CurrentExtent = new RectangleShape(-125, 72, 50, -46);
ShapeFileFeatureLayer newLayer = new ShapeFileFeatureLayer(MapPath("~/SampleData/world/cntry02.shp"));
newLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.RequiredColumnNames.Add(“LONG_NAME”);
newLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
InMemoryFeatureLayer highlightLayer = new InMemoryFeatureLayer();
highlightLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = new AreaStyle(AreaStyles.Country1.OutlinePen,
highlightLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
LayerOverlay overlay = new LayerOverlay(“YourOverlay”);
overlay.Layers.Add(“featureLayer”, newLayer);
overlay.Layers.Add(“highLightLayer”, highlightLayer);
Map1.CustomOverlays.Add(overlay);
InMemoryFeatureLayer highlightLayer = (Map1.CustomOverlays[“YourOverlay”] as LayerOverlay).Layers[“highLightLayer”] as InMemoryFeatureLayer;
highlightLayer.InternalFeatures.Clear();
string longname = feature.ColumnValues[“LONG_NAME”];
if (longname.Contains(“B”)) // please modify the condition to make sure you only add the features active from database
highlightLayer.InternalFeatures.Add(feature);
hi don yes it is working fine
but i have another question and i am hesitating to ask it (because you always help me in my all scenario now i am ashamed to ask again!)
in my database table value can be repeated and multiples for example a province ‘kabul’ can have multiples entries like kabul can active more than one i am going to give you example here please read it
i am going to give you count of 3 province for example
kabul active count is 20
another province active count is 10
another province active count is 5
can i display color density on my database count ? for example kabul active count is 20 so its color density should display high and after that so on counts go low so density goes low?
thanks again anyway your form is really helping and great
please reply me how do i used classbreakstyle in inmemoryfeaturelayer or may be you provide me a better way to change color on my count rows thanks
hi i wants to do like
samples.thinkgeo.com/webedition/howdoisamples/
but how i do this with sql table thanks please reply me soon
Hi Raja,
For ClassBreakStyle you can found many related topic in our forum, for example this one:
thinkgeo.com/forums/MapSuite/tabid/143/aft/5135/Default.aspx
And I think you can query the result from SQLserver after you copy features to inmemory feature layer, you can caeate a special column in the feature then assign the queried result into it.
Wish that’s helpful.
hi i check the form but not very helpful and i also did this with like that
ClassBreakStyle classBreakStyle = new ClassBreakStyle("Prov_Name");
classBreakStyle.ClassBreaks.Add(new ClassBreak(0,
new GeoSolidBrush(GeoColor.SimpleColors.Yellow))));
highlightLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(classBreakStyle);
and it not working can you please provide me sample data that data is coming from database table, which help me in this scenario.
kabul database count is 20 than color it yellow
another province database count active count is 10 than color it red
another province database count active count is is 5 color it yellow dont worry about my database code you just provide me sample code with just example i can done database count and query part but i am stuck on thematic map part which i wants from you just provide me sample code which comes from just one table and change the color and that is my last job everything is done just waiting for your help than i am hoping to deploy my project live thanks
Hi Raja,
In fact we have a HowDoISamples named DrawThematicFeatures is very helpful for use ClassBreakStyle.
I did small change for previous code, please let me know whether that works for you.
// Draw thematic features
ClassBreakStyle classBreakStyle = new ClassBreakStyle("POP_CNTRY");
classBreakStyle.ClassBreaks.Add(new ClassBreak(double.MinValue, AreaStyles.Grass1));
classBreakStyle.ClassBreaks.Add(new ClassBreak(10, AreaStyles.Evergreen2));
classBreakStyle.ClassBreaks.Add(new ClassBreak(20, AreaStyles.Evergreen1));
classBreakStyle.ClassBreaks.Add(new ClassBreak(30, AreaStyles.Crop1));
classBreakStyle.ClassBreaks.Add(new ClassBreak(50, AreaStyles.Forest1));
highlightLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(AreaStyles.Country1);
InMemoryFeatureLayer highlightLayer = (Map1.CustomOverlays["YourOverlay"] as LayerOverlay).Layers["highLightLayer"] as InMemoryFeatureLayer;
// Query on database
DataTable dt;
foreach (DataRow dr in dt)
if (dr["featureName"] == feature.ColumnValues["Feature_Name"])
feature.ColumnValues.Add("classBreakValue", dr["value"]);
hi thanks that is very kind and yes it is working.
Raja,
Please let us know if any other questions.
