I downloaded the Desktop Evaluation Edition 5.0 recently and this is my first post. What I'm trying to do is query a shapefile using a unique ID. Specifically, it is an ID that is made up of section, block and lot numbers (e.g. Section=6, Block=7, Lot=34, ID=6734). I would like to use something similar to the GetFeatureById method, however it seems this only works by querying the generated feature ID. Is there a way to perform a query using a custom unique ID? Does anyone have any suggestions?
You can create a custom FeatureSource and override the GetFeatureByIdsCore API with your code to get features by unique id, which FeatureSource you are using, I use ShapeFileFeatureSource as example below:
public class CustomFeatureSource : ShapeFileFeatureSource { protected override Collection<Feature> GetFeaturesByIdsCore(IEnumerable<string> ids, IEnumerable<string> returningColumnNames) { Collection<Feature> result = new Collection<Feature>(); // Write your code to get features by unique id
Thank you for your help. What I have is an MDI form where the user can input a section, block, and lot number. These numbers are combined to form a unique ID. After the user enters these numbers and clicks a button, I would like the map to zoom into the selected lot which has the corresponding unique ID. I've included the code I have so far. Right now the "pID" variable is used to access the feature ID. Instead I would like this variable to access a column of unique IDs made up of the section, block, and lot numbers. I'm not sure I need a collection feature like you suggest as I only want to select one feature. I also do not know how to pass the "pID" variable to the CustomFeatureSource class. I'm a bit of a newbie with this. Thanks again!
using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Text; using System.Windows.Forms; using ThinkGeo.MapSuite.Core; using ThinkGeo.MapSuite.DesktopEdition;
namespace HelloWorld { public partial class Form2 : Form {
GetFeatureById will call GetFeatureByIdsCore internally and pass in a collection with one id, now I know your column names, so I finish the sample code for you: public class CustomFeatureSource : ShapeFileFeatureSource { protected override Collection<Feature> GetFeaturesByIdsCore(IEnumerable<string> ids, IEnumerable<string> returningColumnNames) { Collection<Feature> result = new Collection<Feature>(); Collection<Feature> features = GetAllFeaturesCore(returningColumnNames); foreach (string id in ids) { foreach (Feature feature in features) { string pId = feature.ColumnValues["section"] + feature.ColumnValues["block"] + feature.ColumnValues["lot"]; if (id == pId) { result.Add(feature); } } }
Thanks James! You steered me in the right direction. Besides some error handling I have it working now. Thanks again for your help.
System.Collections.ObjectModel.Collection<Feature> result = new System.Collections.ObjectModel.Collection<Feature>(); System.Collections.ObjectModel.Collection<Feature> features = new System.Collections.ObjectModel.Collection<Feature>(); features = selection.QueryTools.GetFeaturesByColumnValue("pIDx", pID);
foreach (Feature f in features) { if (f.ColumnValues["pIDx"] == pID) { result.Add(f); }
