Query Performance
Hello all,
if i want to get complete address(contains corssroads), i have to query different layer and get its information.
but i hope query time can decrease...
Could you give me some idea about improve query performance?
I show different query time as follows:
Query_County:00:00:00.0810047
Query_Road:00:00:00.1120064
Query_Node00:00:00.0090005
QueryADR:00:00:00.1680096
Query_County:00:00:00.0080004
Query_Road:00:00:00.0140008
Query_Node00:00:00.0050003
QueryADR:00:00:00.1250071
Query_County:00:00:00.0110007
Query_Road:00:00:00.0110007
Query_Node00:00:00.0070004
QueryADR:00:00:00.1310075
it spend much time in QueryADR.
it code as follows:
               Dim QueryADR As Date
                QueryADR = DateTime.Now()
                Dim road_Layer As ShapeFileFeatureLayer = New ShapeFileFeatureLayer(varADR & "r_10001.shp")
                cross_SQL = "select distinct ADR from [r_10001] where tnode='" & nodeid & "' or fnode='" & nodeid & "'"
                road_Layer.Open()
                road_DT = road_Layer.QueryTools.ExecuteQuery(cross_SQL)
                road_Layer.Close()
                system.console.write("QueryADR:" & (DateTime.Now - QueryADR).ToString() & vbNewLine )
is it wrong in my code?
in addition to my code, which side i still need pay attention?
Carol,
Merry Christmas and Happy New Year.  Thanks for your post and question
In our component, what we did to implement the SQL query is just a wrapper about the OLEDB, so if you want, you could have a try to see it will make any difference by using the OLEDB directly, for more details you can have a look at the sample code in following post:
gis.thinkgeo.com/Support/Dis...aspx#10062
For this performance problem, I can think about 2 ways to go aournd:
1) Import the data to SQL server, build index for it, do query on MsSql2008FeatureLayer. This should be improved for the Index built on SQL Server.
2) If you want to do the Address query, you could have a look at our other product GeoCoder which can combine closely with Desktop Edition.
If you are interested, please contact our support (support@thinkgeo.com) or look at the introduction:
gis.thinkgeo.com/Products/GI...fault.aspx
