Query Tool get distinct values
Hi
I am trying to use the query tool but can’t get it to work
I have loaded a shapefile into a ShapeFileLayer and then try to get a distinct list of values from one of the columns
ShapeFileFeatureLayer.BuildIndexFile(file, BuildIndexMode.DoNotRebuild);
               var layer = new ShapeFileFeatureLayer(file, ShapeFileReadWriteMode.ReadOnly);
               layer.Open();
                   // set style categories
                   var sql = String.Format("Select distinct [{0}] from [{1}]", CategoryColumn, file);
                   var columns = layer.QueryTools.ExecuteQuery(sql);
This however does not work
Is this not the correct way to do this?
Murray
I think my initial problem was the name of the layer.
 I now set the name
 [Code]
  layer.Name = "test";
                    var sql = String.Format("Select distinct  {0} from test", CategoryColumn);
 And I get an error StartIndex cannot be less than zero
 Any ideas?
Hi Murray,
 Thanks for your post, we tried to recreate the problem but the problem didn’t show up on our end, following is our test code, would you please check it and tell us what we missed?
             ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"…\SampleData\Data\Countries02.shp");
             worldLayer.Open();
             string sql = “select distinct CNTRY_NAME from Countries02”;
             worldLayer.QueryTools.ExecuteQuery(sql);
 If the problem is still there? if possible, would you please provide us your data for a further test, you could upload it or  send it to forumsupport@thinkgeo.com.
 Waiting for your further information
 Summer
Thanks Summer
 your example helped me work out where I went wrong.
 Its all working now
 regards
 Murray
Hi Murray,
 Great to hear it helped, if you have any more question, please feel free to let us know.
 Best Regards
 Summer
