Radar Feed
I am doing the reseach for the radar feed. Basically we need present the airplanes on the map based on the plane location at different time. I don't know how to start. I assume we need use the javascript to handle this.
Wilson Jiang
Being able to represent moving vehicles on a map is a very common requested feature and there are a number of way to do that. To direct you more precisely, can you give us a little more information of your scenario. Are you using Live Airport Radar Feed? Can you give us more information of your current system and your requirements? Thank you.
Hi Val,
 Thank you for the quick response. Yes, we use the Live Airport Rada Feed.
 Wilson
Thank you for precising this. I personally don’t have experience working with that in a Web environment. I am passing this post to the Map Suite Web team to see what they think. In the meantime, can you give a little more background on your system and what kind of map you want to use? Thank you.
Hi Wilson,
Just from your description, I think the airplanes should display as the markers, which can move smoothly on the map without postback using Ajax. Here is a demo which includes three different ways to move the markers on the map.
001_WebApplication1.zip (137 KB)
