I have Map Suite Web Edition v3.1.247 running through Internet Explorer 8.0.6001.18702. For some reason, every once in a while when the map loads I get pink tiles on my Dynamic Overlays.
Here is the URL for when the Xs that appear:
/tile_GeoResource.axd?OVERLAYID=Advisors&FORMAT=image%2Fpng&CACHEID=&PAGENAME=default&STYLES=&CLIENTID=My_Body_Map&EXTRA=010119241924&SRS=%2Bproj%3Daea%2Blat_1%3D29.5%2Blat_2%3D45.5%2Blat_0%3D37.5%2Blon_0%3D-96%2Bx_0%3D0%2By_0%3D0%2Bellps%3DGRS80%2Bdatum%3DNAD83%2Bunits%3Dm&BBOX=68224.363158816,-2431946.1977491,2568394.9240667,68224.363158822&WIDTH=256&HEIGHT=256&ZOOM=4
Here is the URL when the layer displays successfully:
/tile_GeoResource.axd?OVERLAYID=Advisors&FORMAT=image%2Fpng&CACHEID=&PAGENAME=default&STYLES=&CLIENTID=My_Body_Map&EXTRA=010127292729&SRS=%2Bproj%3Daea%2Blat_1%3D29.5%2Blat_2%3D45.5%2Blat_0%3D37.5%2Blon_0%3D-96%2Bx_0%3D0%2By_0%3D0%2Bellps%3DGRS80%2Bdatum%3DNAD83%2Bunits%3Dm&BBOX=68224.363158816,68224.363158822,2568394.9240667,2568394.9240667&WIDTH=256&HEIGHT=256&ZOOM=4
This only happens about 1 out of every 3 times I reload the map.
Some specifics on the map:
MapUnit = GeographyUnit.Meter;
CurrentExtent = new RectangleShape( -2300000.0, 1800000, 2800000, -1600000.0 );
Using CustomOverlays with
1 LayerOverlay that has two ShapeFileFeatureLayers (this is the base overlay)
1 LayerOverlay that has an InMemoryFeatureLayer
All are projected using the same Projection object, using the SharedProj4ProjectionClass.
InternalProjection = ESRI:4326 (Lat/Lon)
ExternalProjection = ESRI:102003 (Albers)
My thought is that there is some Client-Side or Server-Side caching going on, because when I clear the Cache in the browser, it does not happen. How do you disable the Client-Side or Server-Side cache? I tried putting Response.Expires and Response.CacheControl headers to no avail. I think it might have something to do with OpenLayer's internal caching mechanism.
- Is there any way to feed a new Unique ID to OpenLayers somehow when OnMapCreated is called?
