1) Can I rotate an image (GeoTiff or bitmap) that overlays a map?
2) Can I create an image from a non-file data source (such as a byte array, bitmap object in memory, or geo-tiff created in memory) and use as a layer (scaled to the map it overlays)? I know the lat/lon and bounds of image. I would prefer as a byte array or bitmap object if possible, GeoTiff in memory as last option.
I get an "Argument out of range exception, Start index cannot be less than zero" error when I tried this example. The world.tif file is in the same directory as my executable. I'm using VS2010. My code is attached.
I'm running the trial version, looks like I can only download 6.0. Is there a way I can get a trial version of 6.0.361? I want to make sure MapSuite can overlay an image and rotate it at specified angle (a requirement from customer) before I buy.
In addition we are looking for support for high-res satellite images (both online and offline). We are also evaluating Esri products, and are wondering if you offer something similar to the "USA Imagery Map" at:
If online Would you please tell us what kind of service you want? If you want to use ArcGis world imagery from their Restful service, could you please have a quick check of our ArcGisServerRestOverlay in web and mvc edition, the quick vedio and self-contained sample can be found at wiki.thinkgeo.com/wiki/Map_S...estOverlay, would you please check if that's what you want in Desktop Edition? we have plans that we will add these stuff in other products, like DesktopEdition after upcoming 7.0 release.
If offline You could use Overlay. TileCache to support high-res satellite images with following code:
Overlay.TileCache = new FileBitmapTileCache(cacheDirectory);
Overlay.TileCache.CacheId = cacheid;
If Localized high-res satellite maps Would you please tell us what type of satellite it is, so that we can check if we support that type. Here is a list of the files we support: wiki.thinkgeo.com/wiki/Map_Suite_Data_Format_Guide
