Guys, do you have a list of recommended hardware requirements for MapSuite besides the minimum required for optimal WPF performance?
TIA,
Klaus
TIA,
Klaus
Klaus,
As far as I know, this is no recommended hardware requirement for this product. Just if you have better hardware, the better performance you get. You know Wpf is self Gpu accelerated.
We use to test this product with low performance graphic card. The drawing performance is almost the same with the higher graphic card. But you set the monitor to high resolution, it pans terrible slow which causes by the UI rendering of DX. We also tested with a better graphic card and four monitor with high resolution, it works fine, the hard disk’s is always busy.
So I think the hardware limitation currently is a good graphic card with a high speed hard disk such as SSD. The other hardwares just keep the average level will be fine.
Here is an article for this issue, hope it helps.
fernicola.org/loquitor/index.php?/archives/21-guid.html
Howard
Howard, as usual, thanks for detailed response.
Klaus,
You are welcome; just feel free to ask if you have more queries.
Howard
