Remove layer issue
With 3.0.348 I have a new issue while trying to remove a layer from an overlay.
This was working correctly with 3.0.335.
Most of the time, the map is refreshed correctly, but sometime (around 1/10) the map is not refreshed and the layer keep being displayed until the user force a refresh.
Here is my code, am I doing something wrong or is this a MS regression ?
Overlay.Lock.EnterWriteLock();
try
    Overlay.Layers.Remove (Layer);
finally
Map.Refresh();
I found some more information.
 The first time I call the function above, it works.
 If I call the function above two times, then only the first call works and only 1 layer is visibly removed.
 Of course, if the user minimise and the maximise the application, the 2 layers are removed, so it’s only a refreshing issue.
 Patrick.
Posted By Patrick on 07-12-2009 04:13 PM
try
finally
Map.Refresh();
Patrick,
I think you did make some minor mistake as following:
LayerOverlay layerOverlay =(LayerOverlay) winformsMap1.Overlays["LayerOverlay"];
layerOverlay.Lock.EnterWriteLock();
try
    layerOverlay.Layers.Remove("StatesLayer");
finally
    //Here should exit wirte lock instead of enter write lock again.
    layerOverlay.Lock.ExitWriteLock();
winformsMap1.Refresh();
Let me know if you have any more problems.
Posted By Patrick on 07-12-2009 04:38 PM
Patrick.
Patrick,
 I tried the following codes and it works fine in version 3.0.348 both remove one and two layers in one button click events:
private void Form1_Load(object sender, EventArgs e)
            winformsMap1.CurrentExtent = new RectangleShape(-126.4, 48.8, -67.0, 19.0);
            ShapeFileFeatureLayer worldShapeLayer = new ShapeFileFeatureLayer(@"…\PostsData\Countries02.shp");
            worldShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.County1;
            worldShapeLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            ShapeFileFeatureLayer statesLayer = new ShapeFileFeatureLayer(@"…\PostsData\USStates.shp");
            statesLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.State1;
            statesLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.OutlinePen.LineJoin = DrawingLineJoin.Round;
            statesLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            ShapeFileFeatureLayer majorCitiesShapeLayer = new ShapeFileFeatureLayer(@"…\PostsData\MajorCities.shp");
            majorCitiesShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.City1;
            majorCitiesShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.City1(“AREANAME”);
            majorCitiesShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle.BestPlacement = true;
            majorCitiesShapeLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            staticOverlay.Layers.Add(“WorldShapeLayer”, worldShapeLayer);
            staticOverlay.Layers.Add(“StatesLayer”, statesLayer);
            staticOverlay.Layers.Add(“majorCitiesShapeLayer”, majorCitiesShapeLayer);
            winformsMap1.Overlays.Add(“LayerOverlay”,staticOverlay);
        private void button1_Click(object sender, EventArgs e)
            LayerOverlay layerOverlay =(LayerOverlay) winformsMap1.Overlays[“LayerOverlay”];
            try
                layerOverlay.Layers.Remove(“StatesLayer”);
            finally
        private void button2_Click(object sender, EventArgs e)
            LayerOverlay layerOverlay = (LayerOverlay)winformsMap1.Overlays[“LayerOverlay”];
            try
                layerOverlay.Layers.Remove(“majorCitiesShapeLayer”);
            finally
Yale,
 You’re right, the bug is on my hand and it’s a typo.
 Sorry & thank you.
 Patrick.
Patrick, You are always welcome!
Let me know if more problems happened.
