Remove Tick event handler runtime
I have successfully added the tick event runtime but now i want to remove it at runtime but its not working.
Basically what i am trying to give user is that they can start auto refresh and also has the power to stop this auto refresh.
I have modified your "AutoRefreshOverlay" page from sample set and pasted that code below.
Apart from this, i also want to give user the button of "Refresh Now" . Right now i am reloading the whole page page user clicks on it. Is there any javascript so by calling it, it can execute tick event functionality manually?
Looking forward to your as usual prompt  reply . :)
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="AutoRefreshOverlay.aspx.cs" Inherits="CSSamples.AutoRefreshOverlay" %>
<%@ Register Assembly="WebEdition" Namespace="ThinkGeo.MapSuite.WebEdition" TagPrefix="cc1" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="w3.org/1999/xhtml">
<head id="Head1" runat="server">
    <link href="~/theme/default/samplepic/style.css" rel="stylesheet" type="text/css" />
    <title>MarkerOverlay AutoRefresh</title>
</head>
<body>
    <form id="form1" runat="server">
    <asp:ScriptManager ID="Map1_Script" runat="server">
    </asp:ScriptManager>
    <asp:UpdatePanel ID="UpdatePanel1" runat="server">
        <ContentTemplate>
            <cc1:Map ID="Map1" runat="server" Width="100%" Height="100%">
            </cc1:Map>
            <asp:Button ID="btnStart" runat="server" Text="Start Refresh" OnClick="btnStart_Click" />
    </asp:UpdatePanel>
    <Description:DescriptionPanel ID="DescPanel" runat="server">
        Demonstrate how to use the AutoRefresh  functinality.
    </Description:DescriptionPanel>
    </form>
</body>
</html>
using System;
using System.Web.UI;
using ThinkGeo.MapSuite.Core;
using ThinkGeo.MapSuite.WebEdition;
namespace CSSamples
    public partial class AutoRefreshOverlay : System.Web.UI.Page
        public SimpleMarkerOverlay MarkerOverlay
            get { return (Map1.CustomOverlays["Vehicle Markers"] as SimpleMarkerOverlay); }
            if (!Page.IsPostBack)
                Map1.CurrentExtent = new RectangleShape(-95.31105, 38.98184, -95.20359, 38.92185);
                WorldMapKitWmsWebOverlay overlay = new WorldMapKitWmsWebOverlay();
                Map1.CustomOverlays.Add(overlay);
                CreateMarkerOverlay();
                SimpleMarkerOverlay markerOverlay = MarkerOverlay;
                markerOverlay.AutoRefreshInterval = TimeSpan.FromMilliseconds(3000);
                //markerOverlay.Tick += new EventHandler<EventArgs>(markerOverlay_Tick);
                markerOverlay.Markers.Add(new Marker(-95.26095, 38.93926, new WebImage(21, 25, -10.5f, -25f)));
                markerOverlay.Markers.Add(new Marker(-95.26086, 38.96956, new WebImage(21, 25, -10.5f, -25f)));
                markerOverlay.Markers.Add(new Marker(-95.25919, 38.96758, new WebImage(21, 25, -10.5f, -25f)));
                markerOverlay.Markers.Add(new Marker(-95.29056, 38.95703, new WebImage(21, 25, -10.5f, -25f)));
                markerOverlay.Markers.Add(new Marker(-95.22653, 38.94278, new WebImage(21, 25, -10.5f, -25f)));
                markerOverlay.Markers.Add(new Marker(-95.26987, 38.93531, new WebImage(21, 25, -10.5f, -25f)));
        /// <summary>
        /// Create Marker overlay
        /// </summary>
        protected void CreateMarkerOverlay()
            SimpleMarkerOverlay markerOverlay = new SimpleMarkerOverlay("Vehicle Markers");
            Map1.CustomOverlays.Add(markerOverlay);
        void markerOverlay_Tick(object sender, EventArgs e)
            SimpleMarkerOverlay markerOverlay = MarkerOverlay; //(SimpleMarkerOverlay)Map1.CustomOverlays["MarkerOverlay"];
            foreach (Marker marker in markerOverlay.Markers)
                double lon = marker.Position.X + new Random(Guid.NewGuid().GetHashCode()).Next(-12, 20) / 5000.0;
                double lat = marker.Position.Y + new Random(Guid.NewGuid().GetHashCode()).Next(-11, 26) / 5000.0;
                marker.Position = new PointShape(lon, lat);
        protected void btnStart_Click(object sender, EventArgs e)
            if (btnStart.Text == "Stop")
                btnStart.Text = "Start";
                markerOverlay.Tick -= new EventHandler<EventArgs>(markerOverlay_Tick);
                markerOverlay.Tick += null;
                //Type type = Map1.GetType();
                //System.Reflection.EventInfo evInfo = type.GetEvent("Tick");
                //evInfo.RemoveEventHandler(Map1, new EventHandler<EventArgs>(markerOverlay_Tick));
            else
                btnStart.Text = "Stop";
Is there anyone looking after this issue?
 Badal,
Sorry for the delayed response a lot of the team is out and have a limited capacity to answer posts.  What error or exception do you get when you try to remove the Tick event at runtime?  As an alternative you could also set the timespan to be a very large value and it should accomplish the same result.
As for having a button to do a refresh our vehicle tracking starter kit does this and you can check it out at:
vehicletracking.thinkgeo.com/ajax/
 i am not gettign any error when i remove the event, the code is gettign executed.
 But the tick event is continue, it does not stops. I want to stop this tick event to be get executed.
 And regarding "vehicle tracking starter kit", is this paid product?
 I only want to give user the button of "Refresh Now" . Right now i am reloading the whole page page user clicks on it. Is there any javascript so by calling it, it can execute tick event functionality manually?
Badal,
The following code doesn't work as it in fact creates a new event handler and try to unhook it, it's not the original event handler we added at the very beginning.
Instead, maybe you can create a custom SimpleMarkerOverlay class, have a boolean property to make the event raise or not, like following.
 class MySimpleMarkerOverlay : SimpleMarkerOverlay
        public bool RaiseEvent;
        protected override void OnTick(EventArgs e)
            if (RaiseEvent)
                base.OnTick(e);
Let us know if you have any issues about this.
"Vehicle Tracking Starter Kit" is a paid version, please reply this post to make it active and our guys will continue to give you a javascript code for this.
