Removed Dots that are Clustered
I’m using the “ClusterPointStyle” solution as a base and I’m trying to hide dots that are clustered.  Is this possible?
Hi Sanjeev,
 Could you please describe more detail about what you want to implement in your scenario?
I was features that have been clustered to not be displayed…
Hi Sanjeev,
 Sorry maybe I haven’t caught the key of your question.
 When you are using ClusterPointStyle, many points will be shown by group, that meant you can only see less points on map, many points are clustered and they won’t be shown on current extent.
 Do you meant you want to hide all the points include the cluster points?
In the example, there are 2 layers:
 volcanoesLayer - I think this shows all volcanoes
 clusterVolcanoesLayer - This only shows clusters
 What I am trying to do is have one layer that shows both, I think I’ve figured it out… I’ve created a custom style that calculates what dots need to be in a cluster and draws them in a special way, and then draws dots that are not in a cluster.
Hi Sanjeev,
 Thanks for let us know your requirement.
 It looks you have completed it, but I think if you have logic to calculate which points need be in cluster and the other not, the simplest way is still create to layers, put them to different layer and assign different style to the layers. But of course this way is not looks so well like what you have implemented.
