dear ,
I use GridFeatureLayer class implements rendering in google map .but gridFeatureLayer class loading the file size of more than 200 trillion, suggesting that memory overflow error. Look forward to your reply!
Render problem
Hi Li,
Could I know what’s the data source? I think GridFeatureLayer should only work for load grid file, and we always render Google Map by our GoogleMapOverlay or GoogleMapsLayer.
Hi Li,
thinks
gridfeaturelayer file is loaded txt file ,the txt contains some drawns grid values, I just need to give him a different worth ranges of different colors on it ,Because this txt file size is 200M, it has been unusual, abnormal type of memory.
Hi Li,
We haven’t found this issue before and unlucky I haven’t found a so big grid file for test today.
If possible, could you please sent your simple test sample with data to support@thinkgeo.com and ask him cc to Don. We will help you solve that.
