Reprojecting a feature in Google Mercator to feature in EPSG 4326?
 Hi All,
How do you reproject a feature that is in google mercator in metres to EPSG 4236 decimal degress?
I know you can reproject the other way around by using:
     Proj4Projection proj4Projection = new Proj4Projection();
  proj4Projection.InternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString();
  proj4Projection.ExternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326);
  proj4Projection.Open();
  Feature geoFeature = proj4Projection.ConvertToExternalProjection(geomShape);
  proj4Projection.Close();
But can I do the reverse?
Bennie
Bennie,
  With Proj4Projection, you can go from one projection to another and vice versa. First, you need to know how you set the internal and the external projection. You have to think logically about your internal and external projections and use the ConvertToInternalProjection or the ConvertToExternalProjection to go one way or another.
I recommend you look at the sample GPS to Google Map wiki.thinkgeo.com/wiki/Map_Suite_De...Desktop.29. You will a very good and common example on how to go from decimal degrees to Google Map.
//Sets the projection parameters to go from Geodetic (EPSG 4326) or decimal degrees to Google Map projection (Spherical Mercator).
proj4.Open();
//Here we go from decimal degrees to Google Map projection
Vertex projVertex = proj4.ConvertToExternalProjection(Longitude, Latitude);
//Here we go from Google Map projection to decimnal degrees
Vertex decimalDegreesVertex = proj4.ConvertToInternalProjection(projVertex.X, projVertex.Y);
proj4.Close();
 Thanks Val, it works great, I think seeing the param hint in the code completion referencing decimal degress through me of the right path a bit.
        // Parameters:
        //   feature:
        //     This parameter is the Feature that contains a BaseShape in decimalDegreesValue
        //     to be projected.
        //  Thanks for your help  Bennie
Bennie,
 I am glad I pointed you out to the right direction on this projection issue. If you have more questions, let us know.
