Resize the component by using Javascript
I want to resize the Map Suite component with a javascript function. I use the ClientId but my map is surrounded by a table and this table hasn't got an ID
I attached a text file with the codes because I can't put the codes in the topic.
Have you a solution to resize my component ?
Thanks in advance.
334-code.txt (1.94 KB)
Pierre,
 We have set the id for the table in the latest version (3.1.0), please get that release and have another try. The table id is Map1.ClientID + "Container".
