Restricting GraticuleAdornmentLayer lines to map extent
Guys,
When using GraticuleAdornmentLayer I do not want to see grid lines outside of the map extent.  In other words, all lines that have a value of N/A should not be dislayed.  How do I achieve this?
Also, is it possible to change resolution of the lines?
TIA.
Hi Klaus,
  You can inhere a CustomGraticuleAdornmentLayer from AdornmentLayer and handle the graticule drawing logic at your wish as demostrated in code.thinkgeo.com/projects/graticule.
   Hope it helps.
 Carlos.
Thank you Carlos. You are right, you have to make a small change in the DrawCore function to have that behavior. Look at the code below. I just added two condition statements for the parallels and the meridians:
protected override void DrawCore(GeoCanvas canvas, Collection<SimpleCandidate> labelsInAllLayers)
    RectangleShape currentExtent = canvas.CurrentWorldExtent;
    double currentMinX = currentExtent.UpperLeftPoint.X;
    double currentMaxX = currentExtent.UpperRightPoint.X;
    double currentMaxY = currentExtent.UpperLeftPoint.Y;
    double currentMinY = currentExtent.LowerLeftPoint.Y;
    //Gets the increment according to the current extent of the map and the graticule density set
    //by the GrsaticuleDensity property
    double increment;
    increment = GetIncrement(currentExtent.Width, graticuleDensity);
    //Collections of GraticuleLabel for labeling the different lines.
    Collection<GraticuleLabel> meridianGraticuleLabels = new Collection<GraticuleLabel>();
    Collection<GraticuleLabel> parallelGraticuleLabels = new Collection<GraticuleLabel>();
    //Loop for displaying the meridians (lines of common longitude).
    double x = 0;
    for (x = CeilingNumber(currentExtent.UpperLeftPoint.X, increment); x <= currentExtent.UpperRightPoint.X; x += increment)
        if ((x <= 180) && (x >= -180))
            LineShape lineShapeMeridian = new LineShape();
            lineShapeMeridian.Vertices.Add(new Vertex(x, currentMaxY));
            lineShapeMeridian.Vertices.Add(new Vertex(x, currentMinY));
            canvas.DrawLine(lineShapeMeridian, new GeoPen(graticuleColor, 0.5F), DrawingLevel.LevelFour);
            //Gets the label and screen position of each meridian.
            ScreenPointF meridianLabelPosition = ExtentHelper.ToScreenCoordinate(canvas.CurrentWorldExtent, x, currentMaxY, canvas.Width, canvas.Height);
            meridianGraticuleLabels.Add(new GraticuleLabel(FormatLatLong(x, LineType.Meridian, increment), meridianLabelPosition));
    //Loop for displaying the parallels (lines of common latitude).
    double y = 0;
    for (y = CeilingNumber(currentExtent.LowerLeftPoint.Y, increment); y <= currentExtent.UpperRightPoint.Y; y += increment)
        if ((y <= 90) && (y >= -90))
            LineShape lineShapeParallel = new LineShape();
            lineShapeParallel.Vertices.Add(new Vertex(currentMaxX, y));
            lineShapeParallel.Vertices.Add(new Vertex(currentMinX, y));
            canvas.DrawLine(lineShapeParallel, new GeoPen(graticuleColor, 0.5F), DrawingLevel.LevelFour);
            //Gets the label and screen position of each parallel.
            ScreenPointF parallelLabelPosition = ExtentHelper.ToScreenCoordinate(canvas.CurrentWorldExtent, currentMinX, y, canvas.Width, canvas.Height);
            parallelGraticuleLabels.Add(new GraticuleLabel(FormatLatLong(y, LineType.Parallel, increment), parallelLabelPosition));
    //Loop for displaying the label for the meridians.
   foreach (GraticuleLabel meridianGraticuleLabel in meridianGraticuleLabels)
       Collection<ScreenPointF> locations = new Collection<ScreenPointF>();
       locations.Add(new ScreenPointF(meridianGraticuleLabel.location.X, meridianGraticuleLabel.location.Y + 6));
       canvas.DrawText(meridianGraticuleLabel.label, new GeoFont("Arial", 10), new GeoSolidBrush(GeoColor.StandardColors.Navy),
           new GeoPen(GeoColor.StandardColors.White, 2), locations, DrawingLevel.LevelFour, 8, 0, 0);
   //Loop for displaying the label for the parallels.
   foreach (GraticuleLabel parallelGraticuleLabel in parallelGraticuleLabels)
       Collection< ScreenPointF> locations = new Collection<ScreenPointF>();
       locations.Add(new ScreenPointF(parallelGraticuleLabel.location.X,parallelGraticuleLabel.location.Y));
       canvas.DrawText(parallelGraticuleLabel.label, new GeoFont("Arial", 10), new GeoSolidBrush(GeoColor.StandardColors.Navy),
           new GeoPen(GeoColor.StandardColors.White,2), locations, DrawingLevel.LevelFour, 8, 0, 90);
Thanks for quick response guys.
Val, copied and pasted your code but it is missing some elements:
CeilingNumber(), FormatLatLong, GraticuleLabel.
graticuleDensity - is this a property I should define?
Also, I need DrawCore to use GraticuleLineStyle and GraticuleTextxxx properties.
Thanks again.
Carlos, thanks for tip.  Thought about this but did not know where to start.
Klaus
Klaus,
 It is all in the LatLongGraticule.cs class file in the Code Community project Latitude Longitude Graticule code.thinkgeo.com/projects/graticule. You can dowload the entire project LatLongGraticule_090827.zip at code.thinkgeo.com/projects/graticule/files. It is a Winforms Desktop project but you can take only LatLongGraticule.cs, it should work for a Wpf project also.
Thanks Val.  Will give it a try.
Hi Klaus,
 Great, just feel free to let us know if you have more queries.
 Howard
