Retreive xcord; ycord and label from a SQLSERVER database
I'm evaluating MapSuite for my project(c# wpfform). Ihave a SQLSERVER table name TOWN where i save information concerning differents town. this my table:
                         TOWN
ID        NAME            XCORD              YCORD
I want to place the different town of my table on the map according the xcord and ycord and then label the added point but i don't know how to do , I need your help. Thankx
Hi Moussa,
Thanks for evaluating our Map Suite product.
To implement the requirement you mentioned, I think you need to write your own FeatureLayer and FeatureSource, maybe you could call them SqlServerPointFeatureSource and SqlServerPointFeatureLayer. You do not need to worry about this, it’s very easy to implement these two classes because we have already had an almost same sample project in our code community. You can find it at following link:
code.thinkgeo.com/projects/s...intfeature
The only difference between that sample and your requirement is that it is using a Microsoft Access database to store the coordinate and label information, so you just need to modify the connect string and some ADO.NET classes used in that sample. Please have a try.
Hope this helps and any more questions please let us know.
Sun
Thank you I will look at it. Before I tried this method and it works this is code line:
 private void ShowPoint()
             try
                 //chargement de la carte
                 RectangleShape imgSize = new RectangleShape(0, 300, 300, 0);
                 GdiPlusRasterLayer imgCalque = new GdiPlusRasterLayer(@“C:\Yamba\Dundas\Dundas\Dundas\ci1.jpg”,imgSize);
                 //ajout des points
                 InMemoryFeatureLayer pointCalque = new InMemoryFeatureLayer();
                 pointCalque.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital1;//new PointStyle(PointSymbolType.Circle,new GeoSolidBrush(GeoColor.StandardColors.Pink),10);
                 pointCalque.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                 //ajout des libelle
                 InMemoryFeatureLayer libCalque = new InMemoryFeatureLayer();
                 libCalque.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = new TextStyle(“designation”, new GeoFont(“Arial”, 10, DrawingFontStyles.Italic), new GeoSolidBrush(GeoColor.StandardColors.Red));
                 libCalque.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                 libCalque.Open();
                 libCalque.Columns.Add(new FeatureSourceColumn(“designation”));
                 //ajout des population
                 InMemoryFeatureLayer popCalque = new InMemoryFeatureLayer();
                 popCalque.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = new TextStyle(“population”, new GeoFont(“Arial”, 10, DrawingFontStyles.Italic), new GeoSolidBrush(GeoColor.StandardColors.Green));
                 popCalque.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                 popCalque.Open();
                 popCalque.Columns.Add(new FeatureSourceColumn(“population”));
                 //ajout des superficie
                 InMemoryFeatureLayer supCalque = new InMemoryFeatureLayer();
                 supCalque.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = new TextStyle(“superficie”, new GeoFont(“Arial”, 10, DrawingFontStyles.Italic), new GeoSolidBrush(GeoColor.StandardColors.Blue));
                 supCalque.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                 supCalque.Open();
                 supCalque.Columns.Add(new FeatureSourceColumn(“superficie”));
                 foreach (DataRow row in source.VILLE)
                     //les points a placer
                     PointShape pointXY = new PointShape(double.Parse(row[“xcord”].ToString()),double.Parse(row[“ycord”].ToString()));
                     pointCalque.InternalFeatures.Add(row[“idville”].ToString(), new Feature(pointXY));
                     //libelle des points placés
                     PointShape pointXYLib = new PointShape(double.Parse(row[“xcord”].ToString())+4, double.Parse(row[“ycord”].ToString())+4);
                     Feature libFeature = new Feature(pointXYLib);
                     libFeature.ColumnValues.Add(“designation”, row[“designation”].ToString());
                     libCalque.InternalFeatures.Add(row[“idville”].ToString(), libFeature);
                      //libelle des population
                     PointShape pointXYPop = new PointShape(double.Parse(row[“xcord”].ToString())+4, double.Parse(row[“ycord”].ToString())-4);
                      Feature popFeature = new Feature(pointXYPop);
                      popFeature.ColumnValues.Add(“population”, row[“population”].ToString());
                      popCalque.InternalFeatures.Add(row[“idville”].ToString(), popFeature);
                      //libelle des superficie
                      PointShape pointXYSup = new PointShape(double.Parse(row[“xcord”].ToString()) + 4, double.Parse(row[“ycord”].ToString()) - 12);
                      Feature supFeature = new Feature(pointXYSup);
                      supFeature.ColumnValues.Add(“superficie”, row[“superficie”].ToString());
                      supCalque.InternalFeatures.Add(row[“idville”].ToString() + “sup”, supFeature);
                 libCalque.Close();//fermeture du calque libelle
                 popCalque.Close();//fermeture du calque population
                 supCalque.Close();//fermeture du calque superficie
                 //ajout des calques
                 LayerOverlay coucheImg = new LayerOverlay();
                 coucheImg.Layers.Add(“imgCalque”, imgCalque);//couche de la carte
                 LayerOverlay couchePoint = new LayerOverlay();
                 couchePoint.Layers.Add(“pointCalque”, pointCalque);//couche des villes
                 LayerOverlay coucheLib = new LayerOverlay();
                 coucheLib.Layers.Add(“libCalque”, libCalque);//couche des libelles
                 LayerOverlay couchePop = new LayerOverlay();
                 couchePop.Layers.Add(“popCalque”, popCalque);//couche des populations
                 LayerOverlay coucheSup = new LayerOverlay();
                 coucheSup.Layers.Add(“supCalque”, supCalque);//couche des superficie
                 //attribuer la couche au control map
                 mapFenetre.Overlays.Add(“coucheImg”, coucheImg);//carte
                 mapFenetre.Overlays.Add(“couchePoint”,couchePoint);//les villes
                 mapFenetre.Overlays.Add(“coucheLib”,coucheLib);//les libelles des ville
                 mapFenetre.Overlays.Add(“couchePop”,couchePop);//la population des villes
                 mapFenetre.Overlays.Add(“coucheSup”,coucheSup);//la superficie des villes
                 mapFenetre.MapUnit = GeographyUnit.DecimalDegree;
                 mapFenetre.BackgroundOverlay.BackgroundBrush = new GeoSolidBrush(GeoColor.GeographicColors.Grass);
                 mapFenetre.CurrentExtent = new RectangleShape(0, 300, 300, 0);
                 mapFenetre.Refresh();
             catch (Exception mes)
                 MessageBox.Show(mes.Message);
 I don’t know if it’s the good way but it works; Tell me something about it please.
 Now I want to do another thing, it is to give the possibilite to the user to change the xcord and ycord of the point by clicking on the map. I give explaining :
 The user have a combobox that contains the list of the town and a button edit. if he click on the button, all the points and labels must disappear only the point that matches the selected town in the combobox and if he clicks on the map the point take the new coordonate. if he click on the button show all, all the points and label must appear
 Thank you
Hi Moussa,
About the code you pasted on this thread, you just host all the data in the SQL server table into an InMemoryFeatureLayer. I don’t think this is better than creating your own SqlServerPointFeatureSource, because it may lead to pressure on the memory of your machine when the dataset becomes large.
About your second requirement, you need to create another InMemoryFeatureLayer instance to host the selected point(s), when the customer click button to begin editing, move the selected point to the new InMemoryFeatureLayer and set other InMemoryFeatureLayers visible to false. Hook the map click event the map control, updates the selected point in the new InMemoryFeatureLayer in the map click event.
Sun
Ok this  what i did
 private void mapFenetre_MapClick(object sender, MapClickWpfMapEventArgs e)
             if (SetXY == true)
                 InMemoryFeatureLayer pointLayer = (InMemoryFeatureLayer)mapFenetre.FindFeatureLayer(“pointCalque”);
                 PointShape pointShape = new PointShape();
                 pointShape.X = e.WorldX;
                 pointShape.Y = e.WorldY;
                 pointShape.Id = idville;
                 int xcord=(int)e.WorldX;
                 int ycord=(int)e.WorldY;
                 //enregistrement dans la base de donnees
                 int i = ville.ModifierXY(xcord, ycord, idville);
                 if (i > 0)
                     pointLayer.Open();
                     pointLayer.EditTools.BeginTransaction();
                     pointLayer.EditTools.Update(pointShape);
                     pointLayer.EditTools.CommitTransaction();
                     pointLayer.Close();
                     //libelle
                     InMemoryFeatureLayer libLayer = (InMemoryFeatureLayer)mapFenetre.FindFeatureLayer(“libCalque”);
                     PointShape libShape = new PointShape();
                     libShape.X = e.WorldX+4;
                     libShape.Y = e.WorldY+4;
                     libShape.Id = idville;
                     libLayer.Open();
                     libLayer.EditTools.BeginTransaction();
                     libLayer.EditTools.Update(libShape);
                     libLayer.EditTools.CommitTransaction();
                     libLayer.Close();
                     //population
                     InMemoryFeatureLayer popLayer = (InMemoryFeatureLayer)mapFenetre.FindFeatureLayer(“popCalque”);
                     PointShape popShape = new PointShape();
                     popShape.X = e.WorldX + 4;
                     popShape.Y = e.WorldY - 4;
                     popShape.Id = idville;
                     popLayer.Open();
                     popLayer.EditTools.BeginTransaction();
                     popLayer.EditTools.Update(popShape);
                     popLayer.EditTools.CommitTransaction();
                     popLayer.Close();
                     //superficie
                     InMemoryFeatureLayer supLayer = (InMemoryFeatureLayer)mapFenetre.FindFeatureLayer(“supCalque”);
                     PointShape supShape = new PointShape();
                     supShape.X = e.WorldX + 4;
                     supShape.Y = e.WorldY - 12;
                     supShape.Id = idville;
                     supLayer.Open();
                     supLayer.EditTools.BeginTransaction();
                     supLayer.EditTools.Update(supShape);
                     supLayer.EditTools.CommitTransaction();
                     supLayer.Close();
                     //rafraichissement
                     mapFenetre.Refresh(mapFenetre.Overlays[“couchePoint”]);
                     mapFenetre.Refresh(mapFenetre.Overlays[“coucheLib”]);
                     mapFenetre.Refresh(mapFenetre.Overlays[“couchePop”]);
                     mapFenetre.Refresh(mapFenetre.Overlays[“coucheSup”]);
                 else
                     MessageBox.Show(“Echec”);
 I am working on what you said, i 'll inform you later. Thank for your availability
Sounds good, any more questions please let me know. And one little thing is that I remember that we have an overload of the Refresh method which can pass in an array of overlays, it would be better to use that overload instead of Refresh many times.
 Sun
Thank for the advice.Now I am trying to add alegend to my map but i can’t find nothing about it. It seems we have to use a method but i don’t know, thanks to help me.
I think i have to search on the forum before posting something . I found the adornmentLayer tutorial and it is working.
Moussa,
Thank Sun for his sharing.
If you want to add a legend to your map, here is a good sample you can look at:
