Reverse Geocoding Does Not Find a Match
I am doing reverse geocoding for millions of records and I am having some records come back without an address match.  When I input the Latitude and Longitude into other systems, I come back with an address.  Here are some examples.
        Latitude
        Longitude
        30.6445639
        -87.9584942
        30.6466151
        -87.926657
        30.6500806
        -87.9269905
        30.3760848
        -87.8415639
        30.3736629
        -87.8391469
        30.3753643
        -87.8509789
        30.3681971
        -87.8418853
        30.2237956
        -88.0299899
        30.628237
        -87.9344217
        30.5908336
        -87.9531697
        30.5523878
        -87.9484604
Hi Kiffany,
I checked these points and found they are far away from a street. In some special areas where our zip codes can’t cover, then no matched result will be returned. We have a zip codes area lists where you can find it in your Geocoder full dataset known as “zipBBX.txt”. I visualized those areas and some of your points:
I also checked some points on Bing Reverse API, looks like they also returns on a city level. OSM does good better, it will include a nearest road. Try nominatim.openstreetmap.org/reverse?format=xml&lat=30.5523878&lon=-87.9484604&zoom=18&addressdetails=1
Personally, I admit there are some enhancements possible on it like we can consider to return a city if none street matched, but that will be taken another days on it.
Hope it helps.
