Roadmap
Hello
I saw on your web site that you will release a new version mid november, do you have a precise road map ? do you think you will support the last version of openlayer : 2.11.
thanks
sebastien
Sebastien,
 Thank you for your question, currently the Daily Development build version of the web edition is using version 2.11-rc1 of Open Layers so this version or greater will be included with the release in mid November.
 If you would like to get your hands on this version now you can download the latest daily development build from the customer portal at helpdesk.thinkgeo.com.
thanks do you have a change log instead of digging into the code ?
 Sebastian,
Currently we only do the change logs on each public release so there isn't one for the daily build.  If you would like to see one I would suggest voting it up on the Enhancement Tracker as that helps set our priorities on what the Map Suite community wants the most.  This item already exists in the enhancement tracker and has recieved some votes, if you have suggestion on how you would like to see this implemented or where to vote it up at check out the following discussion forum post:
gis.thinkgeo.com/tabid/143/a...fault.aspx
The Enhancement Tracker LInk is at:
helpdesk.thinkgeo.com/EnhancementTracker
The enhancement is called Create a ChangeLog page.
