Is there the possibility of the thinkgeo map rotating on the android via multi touch device screen?
Thank you.
Thank you.
Well, running, and how do you make the map always look north automatically?
Hi Elton,
Yes, we support that. Please refer the sample I replied.
Yes, the example works, but it rotates with user action on the tablet screen, I would like it to rotate automatically as the tablet points to the north.
Thank you.
Hi Elton,
It looks I hadn’t get your requirement here, if you are using a map, it should automatic point to north by default.
And if you rotate it to an special angle, then you pan the map, the map will keep this angle.
So what’s the scenario for you?
