Rotation of Added a Draggable Point in Map
there was the post from Adrian 06-09-2010 Adding a Draggable Point in Map. And there was the sample from Yale of using EditInteractiveOverlay.
EditInteractiveOverlay editInteractiveOverlay = new EditInteractiveOverlay();
        ValueStyle valueStyle = new ValueStyle();
        PointShape pointShape;
        private void TestForm_Load(object sender, EventArgs e)
            winformsMap1.CurrentExtent = new RectangleShape(-97.7591, 30.3126, -97.7317, 30.2964);
            winformsMap1.BackgroundOverlay.BackgroundBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 198, 255, 255));
            //Displays the World Map Kit as a background.
            ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay worldMapKitDesktopOverlay = new ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay();
            winformsMap1.Overlays.Add(worldMapKitDesktopOverlay);
            //EditInteractiveOverlay used because it already have the logic for dragging.
            //EditInteractiveOverlay editInteractiveOverlay = new EditInteractiveOverlay();
            //Sets the property IsActive for DragControlPointsLayer to false so that the control point (as four arrows) is not visible.
            editInteractiveOverlay.DragControlPointsLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.IsActive = false;
           editInteractiveOverlay.DragControlPointsLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            //Sets the property IsActive for all the Styles of EditShapesLayer because we are using a ValueStyle instead.
            editInteractiveOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.IsActive = false;
            editInteractiveOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle.IsActive = false;
            editInteractiveOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.IsActive = false;
            //ValueStyle used for displaying the feature according to the value of the column "Type" for displaying with a bus or car icon.
            //ValueStyle valueStyle = new ValueStyle();
            valueStyle.ColumnName = "Type";
            PointStyle carPointStyle = new PointStyle(new GeoImage(@"..\..\Data\car_normal.png"));
            carPointStyle.PointType = PointType.Bitmap;
            PointStyle busPointStyle = new PointStyle(new GeoImage(@"..\..\Data\bus_normal.png"));
            busPointStyle.PointType = PointType.Bitmap;
            valueStyle.ValueItems.Add(new ValueItem("Car", carPointStyle));
            valueStyle.ValueItems.Add(new ValueItem("Bus", busPointStyle));
            editInteractiveOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(valueStyle);
            editInteractiveOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            editInteractiveOverlay.EditShapesLayer.Open();
            editInteractiveOverlay.EditShapesLayer.Columns.Add(new FeatureSourceColumn("Type"));
            editInteractiveOverlay.EditShapesLayer.Close();
            Feature carFeature = new Feature(new PointShape(-97.7507, 30.3092));
            carFeature.ColumnValues["Type"] = "Car";
            Feature busFeature = new Feature(new PointShape(-97.7428, 30.3053));
            busFeature.ColumnValues["Type"] = "Bus";
            editInteractiveOverlay.EditShapesLayer.InternalFeatures.Add("Car", carFeature);
            editInteractiveOverlay.EditShapesLayer.InternalFeatures.Add("Bus", busFeature);
            //Sets the properties of EditInteractiveOverlay to have the appropriate behavior.
            //Make sure CanDrag is set to true.
            editInteractiveOverlay.CanAddVertex = false;
            editInteractiveOverlay.CanDrag = true;
            editInteractiveOverlay.CanRemoveVertex = false;
            editInteractiveOverlay.CanResize = false;
            editInteractiveOverlay.CanRotate = false;
            editInteractiveOverlay.CalculateAllControlPoints();
            winformsMap1.EditOverlay = editInteractiveOverlay;
            winformsMap1.Refresh();
            winformsMap1.DoubleClick += new EventHandler(winformsMap1_DoubleClick);
        void winformsMap1_DoubleClick(object sender, EventArgs e)
            Feature carFeature = new Feature(new PointShape(pointShape.X, pointShape.Y));
            editInteractiveOverlay.EditShapesLayer.InternalFeatures.Add(DateTime.Now.Ticks.ToString(), carFeature);
            winformsMap1.Refresh(winformsMap1.EditOverlay);
        private void winformsMap1_MouseMove(object sender, MouseEventArgs e)
            //Displays the X and Y in screen coordinates.
            statusStrip1.Items["toolStripStatusLabelScreen"].Text = "X:" + e.X + " Y:" + e.Y;
            //Gets the PointShape in world coordinates from screen coordinates.
            pointShape = ExtentHelper.ToWorldCoordinate(winformsMap1.CurrentExtent, new ScreenPointF(e.X, e.Y), winformsMap1.Width, winformsMap1.Height);
            //Displays world coordinates.
            statusStrip1.Items["toolStripStatusLabelWorld"].Text = "(world) X:" + Math.Round(pointShape.X, 4) + " Y:" + Math.Round(pointShape.Y, 4);
        private void btnClose_Click(object sender, EventArgs e)
            this.Close();
 I have question that disturbs me for an year :) . How can I rotate Car and Bus Images?
winformsMap1.EditOverlay.EditShapeLayer.Open();
winformsMap1.EditOverlay.EditShapeLayer.EditTools.BeginTransaction()
winformsMap1.EditOverlay.EditShapeLayer.EditTools.Rotate(feature.Id, new PointShape(0,0),45);
winformsMap1.EditOverlay.EditShapeLayer.EditTools.Update(feature);
winformsMap1.EditOverlay.EditShapeLayer.EditTools.CommitTransaction();
I try code above, But there is no result. Help, please. Thank you.
Nick,
 I am sorry to say that we do not have this functionality to rotate the images now. The code snippet you provided is just trying to rotate the point, so it will not make any effects, sorry for causing you the inconvenience.
 One solution you can think about whether can satisfy your requirement is pre-generate those rotated images and then dynamically change the image attached to the point to achieve this effects, hope it helps.
Yale, thank you for  the rapid answer.
Nick,
 Thanks for your post, any more questions please let us know again,
 Scott,
