RotationProjection on EditOverlay/TrackOverlay
Is there an easy way to add a RotationProjection to the Edit/TrackOverlay of a map?  I've tried adding to the individual layers (DragControlPointsLayer, EditLayer ...etc.) and it seems to rotate fine, but if I drag a control point of a multi-line feature the control point moves in a different direction once I change the rotation (wrong extent being used in DragControlPointsLayer???).
Dave
Dave,
We cannot add a RotationProjection to the Edit/trackOverlay as the features inside the TrackOverlay is already projected (if the map is using a projection). Here is a demo shows how to implement it in another way, please have a look.
721-Post5808.zip (11.5 KB)
Thanks.  Didn't seem to work for me right away but I was able to tweak it a bit and I'm good to go...
      /// <summary>
      /// User changed North location from UI
      /// </summary>
      /// <param name="sender">Ignored</param>
      /// <param name="e">Ignored</param>
      void m_panButton_AngleChanged( object sender, EventArgs e )
         foreach ( Overlay overlay in m_map.Overlays )
            overlay.Lock.EnterWriteLock();
         try
            double saveAngle = m_projection.Angle;
            //Update the TrackOverlay.
            m_map.TrackOverlay.Lock.EnterWriteLock();
            try
               Collection<Feature> projectedTrackFeatures = new Collection<Feature>();
               foreach ( Feature feature in m_map.TrackOverlay.TrackShapeLayer.InternalFeatures )
                  Feature projectedFeature =  m_projection.ConvertToInternalProjection(feature);
                  projectedTrackFeatures.Add(projectedFeature);
               m_projection.Angle = m_panButton.RotationAngle;
               m_map.TrackOverlay.TrackShapeLayer.InternalFeatures.Clear();
               foreach ( Feature feature in projectedTrackFeatures )
                  m_map.TrackOverlay.TrackShapeLayer.InternalFeatures.Add(m_projection.ConvertToExternalProjection(feature));
            finally
               m_map.TrackOverlay.Lock.ExitWriteLock();
            //Update the EditOverlay.
            m_map.EditOverlay.Lock.EnterWriteLock();
            try
               Collection<Feature> projectedEditFeatures = new Collection<Feature>();
               m_projection.Angle = saveAngle;
               foreach ( Feature feature in m_map.EditOverlay.EditShapesLayer.InternalFeatures )
                  projectedEditFeatures.Add(projectedFeature);
               m_map.EditOverlay.EditShapesLayer.InternalFeatures.Clear();
               foreach ( Feature feature in projectedEditFeatures )
                  m_map.EditOverlay.EditShapesLayer.InternalFeatures.Add(m_projection.ConvertToExternalProjection(feature));
               m_map.EditOverlay.CalculateAllControlPoints();
            finally
               m_map.EditOverlay.Lock.ExitWriteLock();
            m_map.CurrentExtent = m_projection.GetUpdatedExtent(m_map.CurrentExtent);
         catch ( Exception )
         finally
               overlay.Lock.ExitWriteLock();
         RefreshMap();
David,
 Thanks for your sharing codes. Do not hesitate to let me know if any further questions.
 Yale.
