how can i find coordinates in a route to be used in tracking application.
Route coordinates
Hi Wael,
Do you means that you need to get the route based on the locations. If so, please try the following steps:
Use the “Routing Index Generator” tools(you can download it from here) to build the routable files.
Create the Routing Engine by the files created in the #1. As shown below:
ShapeFileFeatureSource featureSource = new shapeFileFeatureSource("XXX.shp"); RtgRoutingSource routingSource = new RtgRoutingSource("XXX.rtg"); RoutingEngine routingEngine = new RoutingEngine(routingSource, featureSource); -
Open the Routing Engine.
Call the method GetRoute of Routing Engine as below:
routingResult = routingEngine.GetRoute(routingLayer.StartPoint, routingLayer.EndPoint, routingLayer.StopPoints);And then we can access the routingResult.Rout.Vetices property to get the all coordinates.
More information please refer to:
http://wiki.thinkgeo.com/wiki/map_suite_routing_quick_start_guide
If something misunderstood here please provide more information about your real scenario.
Emil
Thanks Emil,
What I mean is that I have lat/long of a tracked assist and I need to know if it is in the route since I have the route data and drawn.
Hi Wael,
Please try the following steps:
Get the route as Emil mentioned before.
Call the contains method for route got in #1 to determine whether contains the target location. The code maybe like below:
var bufferShape = routingResult.Route.Buffer(distance, GeographyUnit shapeUnit, DistanceUnit distanceUnit);
bool contains = bufferShape.Contains(targetShape);
Peter
