Routing (culture) issuse
Hi all,
I have a small application which shows routes and trun by trun directions between two points.
I have two languages i.e English and Spanish in my application.
when i am in English mode everything works fine but when i change to Spanish mode then nothing happens i.e no route is drawn and aslo no trun by turn direction is shwon.
I have attached the code, please have a look to it.
printmap.txt (108 KB)
Hi Tahir,
Thank you for you post and code snippet. This issue is there is a mismatch between the Regional Settings/Decimal Separator for your clients and the server.
Here is an example of this issue from the Discussion Forums:
gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/12/aft/5381/afv/topic/afpgj/4/Default.aspx#6919
The Bug reported in this issue was resolved and thus should not exist in version 4.5.
This is more of an ASP.NET Web configuration issue rather than an issue in Map Suite so I can only provide you some information about where you can determine what changes to your site need to be made.
1. How to: Set the Culture and UI Culture for ASP.NET Web Page Globalization:
msdn.microsoft.com/en-us/library/bz9tc508.aspx
2. Globalization Issues in ASP and ASP.NET:
support.microsoft.com/kb/893663
Ivan
Hi Ivan
Thanks for your help.
Your were right, it was a decimal issue. I solved it.
Tahir,
 That’s great! Any more questions please let us know again,
 Scott,
