Need help, again. I am now moving into doing routing with ThinkGeo. I am using ThinkGeoCloudVectorMapsOverlay with my keys. The staring point and the ending points are x and y. Using Visual Studio Visual Basic how do I do the route and show it on the map. Tried looking a couple of examples but didn’t get very far.
Routing with Vector Maps?
Hi Steven,
If you want to call our cloud routing API please view here: https://cloud.thinkgeo.com/help/index.html#/Routing
It’s restful and you just need sent request to server and then shows result in any layer.
In https://cloud.thinkgeo.com/ there are some links point to wiki is also helpful.
And I think we have some samples about routing, for example:
Please notice, your ThinkGeoCloudVectorMapsOverlay is for render base layer, it’s not related with your routing, you need put your routing in other layer.
Wish that’s helpful.
Ok, playing around I figured out how to run a route between two x,y’s with the RoutingClient and how to get those results with the RoutingGetRouteResult. I even figured out options with RoutingGetRouteOptions. I am able to see time and distance. I’m using the ThinkGeoCloudVectorMapsOverlay feature to display the map. I use an InMemoryFeatureLayer to place a circle on the maps with “Start” and “End” test above them. That works fine. Now that I have the route result I want to put that route path/line on the map. That’s where I’m getting stuck. Here’s my code I’m trying that doesn’t work.
Private Sub btn_Route_Click(sender As Object, e As EventArgs) Handles btn_Route.Click
Dim rtgClt As New RoutingClient("Key", "Key")
Dim rtgOpts As New RoutingGetRouteOptions()
Dim result As ThinkGeo.Cloud.RoutingGetRouteResult
Dim f As Feature
Dim plat As Double = 39.842934
Dim plon As Double = -75.2415481
Dim dlat As Double = 39.8444378
Dim dlon As Double = -75.126497
Dim sp As New PointShape(plon, plat)
Dim ep As New PointShape(dlon, dlat)
'Clear pointLayer
pointLayer.InternalFeatures.Clear()
'Set route options
rtgOpts.DistanceUnit = DistanceUnit.Mile
rtgOpts.TurnByTurn = True
'Run Route
result = rtgClt.GetRoute({sp, ep}, rtgOpts)
'Get Route Results
Dim rMiles As Double = Math.Round(result.RouteResult.Routes.Item(0).Distance, 2)
Dim rTime As Double = result.RouteResult.Routes.Item(0).Duration.TotalMinutes
'Add route start point to InMemoryFeatureLayer
f = New Feature(plon, plat, "Start") With {.Tag = "Start"}
f.ColumnValues.Add("Place", "Start")
pointLayer.InternalFeatures.Add(f)
'Add route end point to InMemoryFeatureLayer
f = New Feature(dlon, dlat, "End") With {.Tag = "End"}
f.ColumnValues.Add("Place", "End")
'Get route line shape from result
Dim rtLine As LineShape = result.RouteResult.Routes.Item(0).Shape
'Add route line shape to routing layer
rLayer.Routes.Add(rtLine)
mOverlay.Layers.Add(rLayer)
Map_GeocodeMap.Overlays.Add(mOverlay)
rLayer.RouteStyle.OuterPen.Color = GeoColors.Red
pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColors.Red, 10)
mOverlay.Layers.Add("pointLayer", pointLayer)
pointLayer.Open()
Map_GeocodeMap.CurrentExtent = pointLayer.GetBoundingBox()
Map_GeocodeMap.Refresh()
End Sub
Hi Steven,
I build a sample based on your code, it looks works well.
9640.zip (103.3 KB)
