Dear Support,
I have a shp file let's say AustinStreets.shp. And I've built my RTG data. Now I want to route using these data above a google map background.
Please can you give me any hint how to implement such a solution?
I rendered the shapefile using proj4 over the google map overlay successfully. When I set a start point I can convert it to decimal degrees as well. But the routing layer will result in decimal degrees. How can I project it to proj4?
Is there any other way i can follow?
