In order to use a measure tool, I’m using the following class:
/// <summary>
/// This class acts as a measuring tool for the map.
/// Draws a dynamic line and a dynamic circle around the line along with a measurement readout.
/// </summary>
public class RulerTrackInteractiveOverlay : TrackInteractiveOverlay
private const string LineFeatureKey = "lineFeature";
private const string EllipseFeatureKey = "ellipseFeature";
private LineShape _rulerLineShape;
private int _mouseDown;
public DistanceUnit SelectedDistanceUnit { get; set; } = DistanceUnit.Meter;
public string RulerLabel { get; set; } = " meters";
private TextStyle _rulerTextStyle;
public TextStyle RulerTextStyle
get => _rulerTextStyle;
set
_rulerTextStyle = value;
TrackShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = value;
/// <summary>
/// Basic constructor
/// </summary>
public RulerTrackInteractiveOverlay()
RulerTextStyle = new TextStyle("length",
new GeoFont("Arial", 12, DrawingFontStyles.Bold), new GeoSolidBrush(GeoColor.SimpleColors.Black))
TextLineSegmentRatio = 100, YOffsetInPixel = 10
TrackShapeLayer.Open(); //open the layer
TrackShapeLayer.Columns.Add(new FeatureSourceColumn("length")); //make sure there is a length column
//Sets the appearance of the ruler
TrackShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = LineStyles.CreateSimpleLineStyle(GeoColor.FromArgb(150, GeoColor.StandardColors.DarkRed), 4, false);
TrackShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColors.Transparent, GeoColors.Red, 2);
TrackShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = RulerTextStyle;
TrackShapeLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
/// <summary>
/// This handles the mousedown event for the map.
/// Adds the measure features to the map.
/// </summary>
protected override InteractiveResult MouseDownCore(InteractionArguments interactionArguments)
//Sets the first and last point of the line where the user clicks.
InteractiveResult interactiveResult = new InteractiveResult
DrawThisOverlay = InteractiveOverlayDrawType.Draw,
ProcessOtherOverlaysMode = ProcessOtherOverlaysMode.DoNotProcessOtherOverlays
PointShape worldPoint = new PointShape(interactionArguments.WorldX, interactionArguments.WorldY);
double x = worldPoint.X;
double y = worldPoint.Y;
if (x < -180 || x > 180)
x %= 180;
if (y < -90 || y > 90)
y %= 90;
worldPoint = new PointShape(x, y);
_rulerLineShape = new LineShape(new Collection<Vertex> { new Vertex(worldPoint.X, worldPoint.Y), new Vertex(worldPoint.X, worldPoint.Y) });
TrackShapeLayer.InternalFeatures.Add(LineFeatureKey, new Feature(_rulerLineShape));
TrackShapeLayer.InternalFeatures.Add(EllipseFeatureKey, new Feature());
_mouseDown++;
return interactiveResult;
/// <summary>
/// This handles the mousemove event for the map.
/// Dynamically draws the line to the mouse location.
/// </summary>
protected override InteractiveResult MouseMoveCore(InteractionArguments interactionArguments)
InteractiveResult interactiveResult = new InteractiveResult();
if (worldPoint.X < -180 || worldPoint.X > 180)
x = worldPoint.X % 180;
if (worldPoint.Y < - 90 || worldPoint.Y > 90)
y = worldPoint.Y % 90;
if (_mouseDown <= 0) return interactiveResult;
_rulerLineShape.Vertices[_rulerLineShape.Vertices.Count - 1] = new Vertex(worldPoint.X, worldPoint.Y);
TrackShapeLayer.InternalFeatures[LineFeatureKey] = new Feature(_rulerLineShape);
var lengthForLabel = _rulerLineShape.GetLength(GeographyUnit.DecimalDegree, SelectedDistanceUnit);
var angle = 360 - GetAngleFromTwoVertices(_rulerLineShape.Vertices[1], _rulerLineShape.Vertices[0]);
TrackShapeLayer.InternalFeatures[LineFeatureKey].ColumnValues["length"] = string.Format("{0:0.0}", lengthForLabel) + RulerLabel + " " + string.Format("{0:0.0}", angle) + "°";
var lengthForEllipse = _rulerLineShape.GetLength(GeographyUnit.DecimalDegree, SelectedDistanceUnit);
EllipseShape es = new EllipseShape(new PointShape(_rulerLineShape.Vertices[0]), lengthForEllipse);
TrackShapeLayer.InternalFeatures[EllipseFeatureKey] = new Feature(es);
interactiveResult.DrawThisOverlay = InteractiveOverlayDrawType.Draw;
interactiveResult.ProcessOtherOverlaysMode = ProcessOtherOverlaysMode.DoNotProcessOtherOverlays;
/// <summary>
/// This handles the mouse up event for the map.
/// Removes the measure tool that was drawn.
/// </summary>
protected override InteractiveResult MouseUpCore(InteractionArguments interactionArguments)
//Removes the line of the ruler at finishing dragging (at mouse up event).
var interactiveResult = new InteractiveResult
if (_mouseDown != 1) return interactiveResult;
_mouseDown = 0;
TrackShapeLayer.InternalFeatures.Remove(LineFeatureKey);
TrackShapeLayer.InternalFeatures.Remove(EllipseFeatureKey);
Messenger.Default.Send(string.Empty, GlobalVars.ChangeExplainString);
/// <summary>
/// Gets the angle
/// </summary>
/// <param name="b"></param>
/// <param name="c"></param>
/// <returns>The angle between two vertices</returns>
private static double GetAngleFromTwoVertices(Vertex b, Vertex c)
double alpha = 0;
var tangentAlpha = (c.Y - b.Y) / (c.X - b.X);
var peta = Math.Atan(tangentAlpha);
if (c.X > b.X)
alpha = 90 + peta * (180 / Math.PI);
else if (c.X < b.X)
alpha = 270 + peta * (180 / Math.PI);
else
if (c.Y > b.Y) alpha = 0;
if (c.Y < b.Y) alpha = 180;
return alpha;
The ellipse draws fine only if I have the the Geography and Distance units set to Meters in the MouseMoveCore function when getting the length of the lineshape to be used for the ellipse:
_rulerLineShape.GetLength(GeographyUnit.DecimalDegree, SelectedDistanceUnit); //this causes the ellipse to not be drawn at all
_rulerLineShape.GetLength(GeographyUnit.Meter, DistanceUnit.Meter); // this works, but my map unit is never Meter
My map unit is always decimal degrees, and the distance unit can be changed.
Setting both units to meters works fine when near 0,0, but going towards the poles the ellipse should stretch instead of staying a perfect circle. This isn’t the case though.
