Greetings,
I'm aware that you use FDO to read S57 layers, so this is probably out of your control, but I figured I'd ask just in case. I've got my S57 layer rendering the points, lines, and areas fine, and I can use the values stored in the feature columns to see what type of data each feature represents. My problem is there is not attribute data stored in the columns. For instance, I can see that a point is a sounding, but I don't see anywhere where the value of the sounding is actually stored.
For reference, I'm using the charts found at charts.noaa.gov/ENCs/ENCs.shtml
Thanks for your help,
.Ryan.
