Sample from WorldMapKit Error with Map.ExtentOverlay.MouseUp
I just received eval copies of Desktop Edition version 7 and World Map Kit SDK. Compiling with Visual Studio 2012.
Successfully loaded Desktop Edition and made it through the Getting Started tutorial.
Next, I loaded the World Map Kit SDK Sample Desktop Edition project for Visual Studio 12 and tried to open a design view of WorldMapKitSample to look t the GUI design.  I got tow instances of the following error:
"Events cannot be set on the object passed to the event binding service because a site associated withthe object could not be located"
The error stems from thee two lines in WorldMapSample.Designer.cs:
            this.Map.ExtentOverlay.MapMouseDown += new System.EventHandler<ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs>(this.ExtentOverlay_MapMouseDown);
            this.Map.ExtentOverlay.MapMouseUp += new System.EventHandler<ThinkGeo.MapSuite.DesktopEdition.MapMouseUpInteractiveOverlayEventArgs>(this.ExtentOverlay_MapMouseUp);
I am still able to build and run the project but can’t modify the GUI because of this error.
What am I missing?
Thanks in advance
Neil
Hi Neil,
 Thanks for your post, and welcome to MapSuite World. We tried to recreate your problem, but it didn’t show up,  Following is a test vedio on our end for your information:screencast.com/t/WUks2vaxiG. attahced is our test code, would you please check it and tell what we missed, and If possible, a self-contained sample would be highly appreciated.
 Wating for your further information
 Best Regards
 Summer
The sample does run on my PC but I can’t open WorldMapDesignerKit.vb in designer view.
 I had hopes that I would be able to use the sample code as a starting point and tailor it to my application.  As soon as I try to look at the main form in designer view to add a button or other item, I immediately get the error “Events cannot be set on the object passed to the event binding service because a site associated with the object could not be located”, associated with ExtentOverlay_MapMouseUp and ExtentOverlay_MapMouseDown.
 I have a screen shot illustrating the error but don’t know how to get it to you.
 Neil
Hello Neil,
 I did some investigations on Google and seems it is like a bug in VS. A workaround seems to be adding the event in the Form_Load event instead of in the constructor, which means we don’t register those events in Designer view but in the WorldMapDesignerKit.vb file by manually. Like this:
 private void Form1_Load(object sender, EventArgs e){
             winformsMap1.ExtentOverlay.MapKeyDown+=ExtentOverlay_MapKeyDown;
             winformsMap1.ExtentOverlay.MapKeyUp+=ExtentOverlay_MapKeyUp;
 As for how to insert images in the reply, after you submit a pure text answer successfully, please click the Edit button to do more operations in a Editor Tool area.
 Please let us know if the issue persists.
