I apologize in advance if I have missed something obvious, but is there a C# project for loading the OSM shp files into MapSuite?
Sample project for new OpenStreetMap data?
David,
Thank you for your post, I think the only difference between normal shp file and OSM shp file is projection, OSM shp file use the google map projection.
So you can use the normal way to load a OSM shp file and set it’s projection.
