Scale Adornment Layer throws ArgumentException
Version 5 is throwing an exception that version 4.5 did not throw:
Message: The parameter you supplied may not be empty.
Parameter name: text
Title:System.ArgumentException
Extended Properties: Source[2] - MapSuiteCore
Stack Trace[2] -    at mRQ=.3zw=.WT0=(String Wj0=, String Wz0=)
   at ThinkGeo.MapSuite.Core.GeoCanvas.DrawText(String text, GeoFont font, GeoBrush fillBrush, IEnumerable`1 textPathInScreen, DrawingLevel drawingLevel)
   at ThinkGeo.MapSuite.Core.ScaleBarAdornmentLayer.gDY=(GeoCanvas gTY=)
   at ThinkGeo.MapSuite.Core.ScaleBarAdornmentLayer.DrawCore(GeoCanvas canvas, Collection`1 labelsInAllLayers)
   at ThinkGeo.MapSuite.Core.MapEngine.yEw=(AdornmentLayer yUw=)
   at ThinkGeo.MapSuite.Core.MapEngine.Lz8=(IEnumerable`1 vUw=, Bitmap vkw=, GeographyUnit v0w=)
   at ThinkGeo.MapSuite.Core.MapEngine.DrawAdornmentLayers(Bitmap gdiPlusBitmap, GeographyUnit mapUnit)
   at GetMapImageFromLayers(RectangleShape boundingBox, Double bitMapWidth, Double sizeRatio, Collection`1 layers, Boolean showScale)
The scale is a simple layer
            ScaleBarAdornmentLayer layer = new ScaleBarAdornmentLayer();
            layer.Name = "Scale";
            layer.UnitFamily = UnitSystem.Imperial;
that is added to the AdornmentOverlay.Layers.
Was there a breaking change that required an adjustment?
Scott,
 I have tested it by using your sample code, it’s working properly. Please try to get the latest daily build and try it again.
Scott,
 I was experiencing the same issue and was able to solve it by specifying a NumberFormat:
layer.NumberFormat = "0.0";
 Hope that works for you too.
 -Ryan
Ryan,
 Thank you for your information, that’s helped.
 Scott,
 Please try the way which James and Ryan said, and if you still meet the problem, please tell me.
