I've subscribed to the AdornmentOverlay.Drawn event, and I'm logging the DrawingTime. I've noticed that with the scale bar added to my map, the refresh is 0.1 seconds for just the AdornmentOverlay during a Pan operation. This makes the panning seem chunky. Without the scale bar, the panning appears much more fluid to the user.
I think this is happening because it is drawing for every mouse move you are doing as you pan. For geographic layers we can do a trick and pick up the image as you pan. For screen layers it is a bit different as you may want it to change as the person is panning.
What we really need is to know if you really intend to update the image on a pan or other interactive overlay event. If we knew that then we could use the cache of the image already drawn. We need to consider how to do this though at it might be tricky to expose that. You could have an adornment overlay or layer that you might want to refresh on a pan or moving a vertex in edit mode then you are willing to pay for the drawing but other times you may not.
For my app, I cannot think of any use case where I would need to change the display of a scale bar during a pan. I only think it would change during a zoom, since conceptually the appearance of the scale bar is influenced by the zoom.
One thing we could do is to add conditions specifically to things like AdornmentLayers and AdornmentOverlay. We may allow you to specify if the layer or overlay refreshes on a scale change or extent change etc. It is kind of like the IsEmpty property we have now where if you have an overlay that is empty we just skip drawing it all together.
I have a question about this, when we panning the ScaleBar(or ScaleLine) probablly need to be updated.
For example, the scale bar or scale line ratio between Equator with North pole(or south pole) should be different. So when we pan around the world, the scale bar should be updated to reflect its location.
Thanks for pointing that out. For our application, we’re in an isolated, tight, zoomed-in area, and the user will not pan outside this area. So, we’re not too concerned with the issue you pointed out. Mostly, we desire to optimize refresh performance for our small area.
