Selecting a drawn item from the map
We currently have a situation where we click a point on the map and it selects a previously drawn polygonshape.
The code i use for this is as follows:
         Dim clickedPointShape As PointShape = New PointShape(ClickedPosition.X, ClickedPosition.Y)
                Dim QueryPointExtent As RectangleShape = clickedPointShape.GetBoundingBox
                Layer.Open()
                Dim selectedFeatures As System.Collections.ObjectModel.Collection(Of Feature) =       Layer.QueryTools.GetFeaturesInsideBoundingBox(QueryPointExtent, ReturningColumnsType.AllColumns)
                Layer.Close()
The problem i currently have is when a user clicks on an area of the map that the shape doesn't reside in it still returns as existing in the clicked area. I'm pretty sure this is because the test i'm performing is taking into account the shapes bounding box in the query and not the physical outline of the shape.
I need some code that will only test if the physical shape is within the clicked area and not the shapes boundbox.
Aaron
Aaron,
 I tested your code and the result looks strange.
 In fact I think that’s a bug we have, the result shouldn’t return any feature.
 When you GetBoungdingBox of a point, the rectangle will be a rectangle the upperLeft point same to lowerRight point, so that should be a point rectangle in fact.
 I guess you want to when click in map, which shape contains the clicked point return.
 So I suggest you change your code simply for use another API GetFeaturesContaining.
 The changed code should like this:
                 Layer.Open()
                 Dim selectedFeatures As System.Collections.ObjectModel.Collection(Of Feature) = Layer.QueryTools.GetFeaturesContaining(QueryPointExtent, ReturningColumnsType.AllColumns)
                 Layer.Close()
 Wish helpful.
