Serialization of ShapeFileFeatureLayers
I am in the process of developing the functionality to save, then restore the WinFormsMap and all the layers it contains.  I am loading MsSql2008FeatureLayers and ShapeFileFeatureLayers.  I have written classes to inherit from each of these so I can add a few additional properties.  In my earler attempts I only serialized MsSql2008FeatureLayers and everything worked fine.  However, when I try to serialize ShapeFileFeatureLayers I get an error when I try to deserialize.  Here is the code for serilization and deserialization:
      '***** SERIALIZE SNIPPET
      '***** Open a file stream to use for serialization
      oFormatter = New BinaryFormatter()
      oStream = New FileStream(sFileName, FileMode.Create, FileAccess.Write, FileShare.None)
      '***** Save some of the map's property
      oMapProps = New MapProperties
      oLayerOverLay = CType(oMap.Overlays("Static"), LayerOverlay)
      With oMapProps
         .BoundingBox = oMap.CurrentExtent
         .MapUnit = oMap.MapUnit
         .NumberOfLayers = oLayerOverLay.Layers.Count
         .CoordinateSystemInfo = oMap.CoordinateSystem
      End With
      oFormatter.Serialize(oStream, oMapProps)
      '***** Now save all the layers, save the bottom one first so the order will
      '***** be correct when deserialized
      For i = 0 To oLayerOverLay.Layers.Count - 1
         oFormatter.Serialize(oStream, oLayerOverLay.Layers(i))
      Next i
      oStream.Close()
      '***** DESERIALIZE SNIPPET
         '***** Open a file stream to use for deserialization
         oStream = New FileStream(sWorksetFile, FileMode.Open, FileAccess.Read, FileShare.Read)
         For i = 0 To oMapProps.NumberOfLayers - 1
            oObjLayer = oFormatter.Deserialize(oStream)
               oShapefileFeatureLayer = CType(oObjLayer, CustomShapefileFeatureLayer)
               oLayerOverLay.Layers.Add(oShapefileFeatureLayer.Name, oShapefileFeatureLayer)
               If oShapefileFeatureLayer.IsProjected Then
                  Dim oProj4 As New ManagedProj4Projection
                  oProj4.InternalProjectionParameters = oShapefileFeatureLayer.InternalProjParams
                  oProj4.ExternalProjectionParameters = oShapefileFeatureLayer.ExternalProjParams
                  oProj4.Open()
                  oShapefileFeatureLayer.FeatureSource.Projection = oProj4
               End If
               SetBoundingBox(oShapefileFeatureLayer)
               'oShapefileFeatureLayer.BoundingBox = oShapefileFeatureLayer.GetBoundingBox()
            End If
The problem manifests when I try to use the GetBoundingBox Method on the ShapeFileFeatureLayer.  I get the error "Object reference not set to an instance of an object."  Here is the stack trace:
   ThinkGeo.MapSuite.Core.ShapeFileFeatureSource.GetBoundingBoxCore()
       GeoFrame.EXE: N 00048
   ThinkGeo.MapSuite.Core.FeatureSource.GetBoundingBox()
       GeoFrame.EXE: N 00243
   ThinkGeo.MapSuite.Core.FeatureLayer.GetBoundingBoxCore()
       GeoFrame.EXE: N 00079
   ThinkGeo.MapSuite.Core.Layer.GetBoundingBox()
       GeoFrame.EXE: N 00075
   MapUtilities.LayerUtils.SetBoundingBox(oFeatureLayer As FeatureLayer)
       GeoFrame.EXE: N 00107
   MapUtilities.LayerUtils.OpenWorkingSet(oMap As CustomWinformsMap, sWorksetFile As String)
       GeoFrame.EXE: N 01167
I have been searching the forums for any clues and I read that the CloneDeep method uses Serialize in its implementation, with the limitation that it does not inclued Encoding.  And, indeed, if I query the encoding of the ShapeFileFeatureLayer that has just been deserialized I get the error:
System.ArgumentNullException was unhandled
  Message=The parameter you supplied may not be null.
Parameter name: DBaseEngine
  Source=MapSuiteCore
  ParamName=DBaseEngine
  StackTrace:
       at ThinkGeo.MapSuite.Core.x6d719af406ea4c2c.xddc71efc9badd3c7(Object xf85c38ac7d1447ea, String x34decc57f0820440)
       at ThinkGeo.MapSuite.Core.ShapeFileFeatureSource.get_Encoding()
       at ThinkGeo.MapSuite.Core.ShapeFileFeatureLayer.get_Encoding()
  InnerException:
When I try to set the encoding to System.Text.Encoding.Default (as a workaround) I get the same error.  Don't know if this is related to the error I get calling GetBoundingBox or not.
Any ideas?
Steve
Steven,
 I do not think the exception caused by the GetBoundingBox is the same error with the Encoding problem. I doubt it is related with the Projection set to the layer cannot be sterilized. While, also I noticed the layer is customized one called CustomShapefileFeatureLayer, could you show me a complete example to recreate this problem?
Yale,
 Thanks for your response.  I will send a sample to you shortly.
 Steve
Steven,
Try the following code when you deserialize the shape file feature layer, hope it can fix your problem.
oShapefileFeatureLayer = CType(oFormatter.Deserialize(oStream), ShapeFileFeatureLayer)
oShapefileFeatureLayer.Close()
oShapefileFeatureLayer.Open()
Yale,
Sorry to take so long to reply.  Thanks for your solution, it works perfectly!
Steve
Steven,
 Thanks for letting me know this.
