I am experiencing a new problem which I believe to have started with the recent upgrade. I was unable to successfully restore to the previous version of Map Suite Web so I am unable to confirm that this issue was not happening before. The problem occurs with server side image caching. We are using a MrSid image as part of our static layer that gets cached server side. The initial build with a dyanamic overlay works just fine. Everything draws correctly and everything lines up. However, if you start panning a little to the left or to the right, the dyanamic layer is no longer in synch with the static layer. It is as if the dynamic layer properly pans and shifts the images slightly left or slightly right, but the static layer redraws the previous image. I've attached a sample showing how the dyanamic layer shapes don't properly line up with the static layer imagery. Map_on.jpg is when the two overlays line up. Map_off.jpg is when the two overlays are not in synch. If I turn off server side caching of the static layer everything is fine. Like I said, from the best I can tell, it is as if the engine is using the cached image of the original image rather than redrawing or using a different cached image for the new extent.
I hope I was able to convey the problem at hand.
Thank you,
Binu
