Set CurrentExtent based on zoom level and center point
I am trying to open the map centered at some point with a given zoom level. In my server code I have this:
var googleZoomLevels = new GoogleMapsZoomLevelSet();
var centerPoint = new PointShape(-3000000, 6000000);
ZoomTo(centerPoint, googleZoomLevels.ZoomLevel04.Scale);
However, with this I get the following javascript error:
Uncaught TypeError: Cannot read property 'left' of undefined helper_GeoResource.axd:66
ConvertJsonToBounds helper_GeoResource.axd:66
Class.Extent.initExtent parser_GeoResource.axd:397
Class.Extent.createMap parser_GeoResource.axd:993
CreateAllMaps helper_GeoResource.axd:289
(anonymous function)
I think this is because CurrentExtent is not set.
My question is, how can I calculate the CurrentExtent from my center point and current zoom level? Or some other way to achieve this.
Thank you,
Sindre
Hi Sindre,
I modified the UseGoogleMap sample a little, and it could work with your code, please get it and have a try.
Controller
            Map map = new Map("Map1",
                new System.Web.UI.WebControls.Unit(100, System.Web.UI.WebControls.UnitType.Percentage),
                new System.Web.UI.WebControls.Unit(100, System.Web.UI.WebControls.UnitType.Percentage));
            map.MapUnit = GeographyUnit.Meter;
            map.CustomOverlays.Add(new GoogleOverlay());
            map.ZoomTo(centerPoint, googleZoomLevels.ZoomLevel10.Scale);
            return View(map);
View
       @{Html.ThinkGeo().Map(Model).Render();}
Edgar
