Set Layer Visible True/False
I want to set different layers Visible True and False.
Currently I am use JavaScript for that like below:
function toggleLayer(layerId) {
        debugger;
        var layer = Map1.getLayer(layerId);
        if (layer) {
            if (layer.visibility) {
                layer.visibility = false;
                Map1.redrawLayer(layerId);
            else {
                layer.visibility = true;
Now here problem is If layer was Visible false and when I check check box then its visible true and visible on map,
but when I uncheck any checkbox that time visible layer can not set false, so what is the problem??
Hi Vivek,
 Please try this code as below:
        if (layer) {
                layer.setVisibility(false);
            else {
Thanks Don,
 It’s Works…
Hi Vivek,
 I am glad to hear that works for you.
