I am using Minimap tool for Thinkgeo using below code:
tools.MiniMapMapTool().Enabled(True)
Now I want this utiliy in particular Div tag for HTML in the page (Outside Thinkgeo Map)
For understanding I am attaching image.
How can I do this?
Hi Vivek,
I think that you can get “MiniMapTool” div signature as following statements, but you can’t move out the map zone.
<script language="javascript" type="text/javascript">
var cloneNode;
var
OnMapCreated = function mapCreated(e) {
var a = Map1.getControlsByClass("OpenLayers.Control.OverviewMap");
cloneNode =
a[0].div.cloneNode();
cloneNode.id =
"overView1";
cloneNode.style.position = "absolute";
cloneNode.style.left = "50px";
a[0].div.style.left = "700px";
</script>
Hi Vivek,
This sample code just show how to find the minimap div and modify its position, but we still cannot move it out of the map area.
Thanks Don…
Can possible to display current map-extent on div tag?
Hi Vivek,
As below is the code to alert current extent when extent changed, you can put the result to your div tag instead of alert it.
var OnMapCreated = function mapCreated(map) {
tgMap = map;
tgMap.events.register(‘moveend’, null, function (evt) {
var currentExtent = map.getExtent();
alert(currentExtent.toString());
tgMap.events.register(‘zoomend’, null, function (evt) {
Thanks Don…
It’s work
It display as -10310485.60834,-5092697.4647323,-291731.43834,92790.533412266,
Is it possible to convert it into ratio like 1:10 000 means in ratio?
And how it is done?
Hi Vivek,
You can use map.getScale() to replace map.getExtent(), the scale means ratio, but you should want to convert the result to the format you need.
Thanks Don its working…
Hi Vivek,
I am glad to hear that works for you.
Hi Vivek,
Are you able to move the mini map outside Thinkgeo Map? could you please share the codes?
No guangming, As it is an inbuilt functionality of thinkgeo, so we can not move outside Thinkgeo Map.
You can just create a clone of map into DIV as example given by DON Above.
Hi Vivek&Guangming,
I did an investigation and find out a flexible way to put any controls out of ThinkGeo map. Please try the blow codes:
<style>.olControlOverviewMap {background:#ff0000;width: 200px;}
.olControlOverviewMapElement {background:#00ff00 !important;}</style><script type=<code style="color: blue;">"text/javascript"<code style="color: #000000;">>OnMapCreated =function(map) {vardefaultOverviewMap = map.getControlsByClass("OpenLayers.Control.OverviewMap");if(defaultOverviewMap) {map.removeControl(defaultOverviewMap[0]);}varexternal_control =newOpenLayers.Control.OverviewMap({div: document.getElementById(‘external_control’)});map.addControl(external_control);}</script>
From code, you can see, not only we can specify a div as the control container, we even can override its style. and in the end, we can get the such result:
If there is anything confused on those codes, please feel free to let us know.
Thanks Troy for the Sample…
Vivek,
You are welcome.
If any other queries, please feel free to let us know.
Can we do this to Legend image in adornmentoverlay?
Guangming,
Sorry to say, it is just fit for controls and the legend is built on adormentlayer.
