I am to add new layer with this shapefile (attached)..in Map SuiteExplorer.
but I am not able to load the feature table.. . it gave me the error"this Microsoft database engine could not find the object 'AD047A~1'. Make sure the object exists and that you spell its name and path name correctly."
What's so strange is that.. if I move the files to another folder.. then, I will be able to add the layer and show the features! Why is that?
this is giving my a problem.. cuz in my code I need to do something like
..Layer.QueryTools.ExecuteQuery(..); which throwed me the same error I had when I used the map explore to open this shape file.. I have all my shape files in the folder which I can't open this shape file with.. and .. other shape files were fine in this folder..
Could you help?
thanks!
Roson
1535-shapefile.zip (346 KB)
