Hi ThinkGeo,
We are having issues with a specific projections in ThinkGeo WebForms displaying offset. The projection is EPSG:32026 - NAD27 / Oregon North. The curious thing about this issues is we have many other shapefiles and projections that have worked just fine with our current set up of code. Only this one appears to display offset. I have also converted this shapefile in QGIS to the WGS84 projection and when I run it through our code it works just fine.
Is there something we are missing?
Our test environment and sample shapefiles:
using System;
using ThinkGeo.MapSuite.WebForms;
using ThinkGeo.MapSuite.Drawing;
using ThinkGeo.MapSuite.Layers;
using ThinkGeo.MapSuite.Shapes;
using ThinkGeo.MapSuite.Styles;
using ThinkGeo.MapSuite;
using System.IO;
using System.Web.UI;
namespace Test
public partial class TestForm : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
string strFile = @“C:”; //Local File Path for testing
string strFileName = “StreetSample.shp”; //“StreetSampleWGS84.shp”
try
if (!Page.IsPostBack)
//Determines if the file exists.
if (File.Exists(strFile + strFileName))
lblExists.Text = “File Exists”;
else
lblExists.Text = “File Does Not Exist”;
Map1.MapBackground = new GeoSolidBrush(GeoColor.FromHtml("#E5E3DF"));
string applicationID = "BING KEY HERE";
//Bing Maps
BingMapsOverlay mobjBingsOverlay = new BingMapsOverlay("ROADS", applicationID);
mobjBingsOverlay.MapStyle = BingMapsStyle.Road;
mobjBingsOverlay.Name = "Roads";
Map1.CustomOverlays.Add(mobjBingsOverlay);
//Google Maps
//GoogleOverlay mobjGoogleOverlay = new GoogleOverlay();
//mobjGoogleOverlay.GoogleMapType = GoogleMapType.Hybrid;
//mobjGoogleOverlay.Name = "Roads";
//Map1.CustomOverlays.Add(mobjGoogleOverlay);
Map1.MapUnit = GeographyUnit.Feet;
LayerOverlay objOverlay = new LayerOverlay();
ShapeFileFeatureLayer objAllRoads = new ShapeFileFeatureLayer(strFile + strFileName);
ShapeFileFeatureLayer.BuildIndexFile(strFile + strFileName);
objAllRoads.Name = "All Roads";
string strFILE = strFile + strFileName;
string strPRJ = strFILE.ToUpper().Replace(".SHP", ".PRJ");
string strProjection = null;
strProjection = File.ReadAllText(strPRJ);
Proj4Projection mobjProjectionJUR = new Proj4Projection();
mobjProjectionJUR.InternalProjectionParametersString = Proj4Projection.ConvertPrjToProj4(strProjection);
mobjProjectionJUR.ExternalProjectionParametersString = Proj4Projection.GetBingMapParametersString();
//mobjProjectionJUR.ExternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString();
LineStyle objLine;
TextStyle objText;
string strLabel1 = "STREET_CAT";
// ### ZoomLevel 19-20 (Close Up) ###
ZoomLevel objZoom1 = objAllRoads.ZoomLevelSet.ZoomLevel19;
objZoom1.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
objText = GetHaloLabelRender(9.5F, strLabel1, GeoColor.StandardColors.Gray);
SetStandardRoadLabel(ref objText, 5);
objLine = LineStyles.LocalRoad1;
objZoom1.CustomStyles.Add(objText);
objZoom1.CustomStyles.Add(objLine);
objAllRoads.ZoomLevelSet.CustomZoomLevels.Add(objZoom1);
// ### ZoomLevel 17-19 ###
ZoomLevel objZoom2 = objAllRoads.ZoomLevelSet.ZoomLevel17;
objZoom2.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level18;
objText = GetHaloLabelRender(8.5F, strLabel1, GeoColor.StandardColors.Gray);
SetStandardRoadLabel(ref objText, 80);
objLine = LineStyles.LocalRoad2;
objZoom2.CustomStyles.Add(objText);
objZoom2.CustomStyles.Add(objLine);
objAllRoads.ZoomLevelSet.CustomZoomLevels.Add(objZoom2);
// ### ZoomLevel 16-16 ###
ZoomLevel objZoom3 = objAllRoads.ZoomLevelSet.ZoomLevel16;
objZoom3.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level16;
objText = GetHaloLabelRender(7.5F, strLabel1, GeoColor.StandardColors.Gray);
SetStandardRoadLabel(ref objText, 70);
objLine = LineStyles.LocalRoad3;
objZoom3.CustomStyles.Add(objText);
objZoom3.CustomStyles.Add(objLine);
objAllRoads.ZoomLevelSet.CustomZoomLevels.Add(objZoom3);
// ### ZoomLevel 14-15 ###
ZoomLevel objZoom4 = objAllRoads.ZoomLevelSet.ZoomLevel14;
objZoom4.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level15;
objText = GetHaloLabelRender(6.5F, strLabel1, GeoColor.StandardColors.Gray);
SetStandardRoadLabel(ref objText, 125);
objZoom4.CustomStyles.Add(objText);
objLine = LineStyles.LocalRoad4;
objZoom4.CustomStyles.Add(objLine);
objAllRoads.ZoomLevelSet.CustomZoomLevels.Add(objZoom4);
// ### ZoomLevel 1-13 ###
ZoomLevel objZoom5 = objAllRoads.ZoomLevelSet.ZoomLevel01;
objZoom5.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level13;
objLine = new LineStyle(new GeoPen(GeoColor.StandardColors.Gray, 0.5F));
objZoom5.CustomStyles.Add(objLine);
objAllRoads.ZoomLevelSet.CustomZoomLevels.Add(objZoom5);
objAllRoads.FeatureSource.Projection = mobjProjectionJUR;
objOverlay.Layers.Add(objAllRoads);
Map1.CustomOverlays.Add(objOverlay);
objAllRoads.Open();
Map1.CurrentExtent = objAllRoads.GetBoundingBox();
objAllRoads.Close();
catch (Exception ex)
lblSuccess.Text = ex.Message;
private TextStyle GetHaloLabelRender(float FontWidth, string strRenderField, GeoColor TextColor, bool blnOnTop = false, int intAlpha = 255)
if (blnOnTop == true)
return TextStyles.CreateSimpleTextStyle(strRenderField, "Arial", FontWidth, DrawingFontStyles.Bold, TextColor, GeoColor.StandardColors.White, 3, 10, 10);
else
return TextStyles.CreateSimpleTextStyle(strRenderField, "Arial", FontWidth, DrawingFontStyles.Bold, TextColor, GeoColor.StandardColors.White, 3, -10, -10);
private void SetStandardRoadLabel(ref TextStyle objTextStyle, int intGridSize)
objTextStyle.DuplicateRule = LabelDuplicateRule.OneDuplicateLabelPerQuadrant;
objTextStyle.OverlappingRule = LabelOverlappingRule.NoOverlapping;
objTextStyle.BestPlacement = true;
objTextStyle.GridSize = intGridSize;
objTextStyle.TextLineSegmentRatio = double.MaxValue;
objTextStyle.SuppressPartialLabels = true;
Thank you,
Neil
SampleShapefiles.zip (17.9 KB)
