Any luck with the issue that i’m having with shapefile. The code below is very standard and I got it form the samples. The file in question UGA_region.shp was copied to that folder including other shape files form our vendor. Except for that one others show up on the map fine.
if (!Page.IsPostBack)
// Map1.CurrentExtent = new RectangleShape(-13939426.6371, 6701997.4056, -7812401.86, 2626987.386962);
Map1.MapUnit = GeographyUnit.Meter;
Map1.MapTools.OverlaySwitcher.Enabled = true;
Map1.MapTools.MouseCoordinate.Enabled = true;
GoogleOverlay google = new GoogleOverlay(“Google Map”);
google.JavaScriptLibraryUri = new Uri(ConfigurationManager.AppSettings[“GoogleUriV3”]);
google.GoogleMapType = GoogleMapType.Normal;
ShapeFileFeatureLayer shapeFileFeatureLayer = new ShapeFileFeatureLayer(MapPath("~/SampleData/USA/UGA_region.shp"));
shapeFileFeatureLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.FromArgb(100,212,220,184), GeoColor.FromArgb(255,132,132,154), 1);
shapeFileFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
shapeFileFeatureLayer.FeatureSource.Projection = proj4;
LayerOverlay shapeOverlay = new LayerOverlay(“Shape Overlay”, false, TileType.SingleTile);
shapeOverlay.Layers.Add(shapeFileFeatureLayer);
shapeOverlay.TransitionEffect = TransitionEffect.None;
Map1.CustomOverlays.Add(shapeOverlay);
