Hello ThinkGeo,
a while ago I had problems with data projection on GoogleMaps-Layer.
Now I'm facing the same offset problem with BingMaps.
I tried my solution from the upper post but it does not work.
Also I have a second problem you can see here: screencast.com/t/klPr3T98h
In the video I try to center on the position where the river makes a loop. When zooming to scale values smaller than 18023 the maps center point jumps to incorrect positions and BingMap does not show the expected background. Is this a bug in BingMaps-Layer?
I have attached a small sample application where you can see my issues.
Any solution?
Thomas
GISWPF_BingMaps.zip (276 KB)
