Shapefile with PRJ throws exception "Initialize Ellps Failed!"
When I open a layer containing a shapefile with an imported PRJ spatial definition, it throws an exception: Initialize Ellps Failed!.
I use Thinkgeo Wpf Desktop Edition 5.0. My regional settings is on "French (France)".
Here's the prj definition:
PROJCS["NTF_France_II_degrees",GEOGCS["GCS_NTF",DATUM["D_NTF",SPHEROID["Clarke_1880_IGN",6378249.2,293.46602]],PRIMEM["Greenwich",0],UNIT["Degree",0.0174532925199432955]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",600000],PARAMETER["False_Northing",2200000],PARAMETER["Central_Meridian",2.337229166666667],PARAMETER["Standard_Parallel_1",46.8],PARAMETER["Scale_Factor",0.99987742],PARAMETER["Latitude_Of_Origin",46.8],UNIT["Meter",1]]
Here's the callstack:
   at mBQ=.eUk=.kEk=(2kI= kUk=, yVw= kkk=, 8l8= k0k=, Bhc= lEk=, Dictionary`2 lUk=)
   at mBQ=.eUk=.iEk=(String iUk=)
   at ThinkGeo.MapSuite.Core.ManagedProj4Projection.OpenCore()
   at ThinkGeo.MapSuite.Core.Projection.Open()
   at ThinkGeo.MapSuite.Core.FeatureSource.Open()
   at ThinkGeo.MapSuite.Core.FeatureLayer.OpenCore()
   at ThinkGeo.MapSuite.Core.Layer.Open()
   at WpfCartography.CWpfCartography.GetFullExtent(GeoCollection`1 Layers, Overlay OSMOverlay, Boolean bUseOSM) in D:\integration\trunk\sources\Report Elements\Wpf\Cartography\WpfCartography\WpfCartography.xaml.cs:line 857
   at WpfCartography.CWpfCartography.ComputeExtentRestriction() in D:\integration\trunk\sources\Report Elements\Wpf\Cartography\WpfCartography\WpfCartography.xaml.cs:line 493
   at WpfCartography.CWpfCartography.Refresh() in D:\integration\trunk\sources\Report Elements\Wpf\Cartography\WpfCartography\WpfCartography.xaml.cs:line 452
When the Regional settings is "English (United States)", I don't get the exception.
P.OM
Hi Puthirak,
It seems that you customized the InternalProjectionParametersString and ExternalProjectionParametersString, could you please provide us a self-contained sample (with the source shape file) to recreate this issue? It will be helpful for tracking the root cause.
Ivan
Hi Ivan,
Here's your self-contained sample...
P.OM
P.OM,
I am afraid this is a potential bug related with culture info, could you do a real quick try on the following API both on English and French region settings to see if the returned back projection string makes any difference based on region?
string str = Proj4Projection.ConvertPrjToProj4(prjString);
Hi Yale,
With fr-FR CultureInfo, we have:
+proj=lcc +lat_1=Non Numérique +lat_0=Non Numérique +lon_0=Non Numérique +k_0=0 +x_0=600000 +y_0=2200000 +a=0 +b=0 +units=m +no_defs
With en-US CultureInfo, we have:
+proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=2.33722916666667 +k_0=0.99987742 +x_0=600000 +y_0=2200000 +a=6378249.2 +b=6356514.99990419 +units=m +no_defs
with Invariant CultureInfo, we have:
So setting temporarily the thread CultureInfo to Invariant before the prj to proj4 conversion should do the trick.
P.OM
Puthirak,
We're glad that your issue has been resolved. Please let us know if you have further questions.
Ivan
