Should I use RTG file
Do I need RTG file when routing, İf no how can I route? İf yes I need rtg file for Turkey.
To use Map Suite Routing, you need a  line based layer (Road Network) and build the routing index (RTG file). You can build the RTG file using MapSuite Routing that comes with the product itself. If you want routable data for Turkey, you need to contact a data provider for that country or a world data provider such as Navteq.
Thank you Val,
   I used Map Suite Routing tool to build RTG file. İt builds the RTG file but it gives me a warning like "This method will return to many cells that might caouse performance problem. Please using GetIntersectingRowColumnRange method instead."
 What should I do?
What is the size of the shapefile? Are you sure this is a line based shapefile? If you think the shapefile is appropriate for routing, could you please send it to us? You can contact support@thinkgeo.com for the instruction on how to send the shapefile to us. Thank you.
Thank you Val,
 I think it is not a line based shapefile. I contacted with our data provider and I am waiting now.
Ok, let us know when you have more information. Thank you.
Val,
 Could you send me some RTG files because I wil send them to our data provider.
 Ayhan
Ayhan,
 You will find lots of RTG files under installation directory.
Also you can refer to the installed sample "BuildRoutingIndexFile.cs" about how to build different RTG files.
Thank you very much Johnny.
 Ayhan
It’s our pleasure. Johnny
