Show area and radius on selecting / editing a circle
I am displaying the area and radius of a circle when I edit it on the map using the following:
Feature feature= wpfMap1.EditOverlay.EditShapesLayer.InternalFeatures[0];
                double area = 0;
                double radius = 0;
                double pi = 3.1416;
                if (feature.GetShape() is AreaBaseShape)
                    area += (feature.GetShape() as AreaBaseShape).GetArea(GeographyUnit.Meter, AreaUnit.SquareMeters);
                    radius = System.Math.Sqrt(area / pi);
                txtRadius.Text = "Radius: " + string.Format(CultureInfo.InvariantCulture, "{0:N3} {1}", radius, "Mtrs");
Since I am just checking whether the shape is an AreaBaseShape, the radius shows for all kinds of area shapes, like polygon areas. I want to limit this to circles alone. How do I do that?
Jacob
Hi Jacob,
 In fact the circle is saved as polygon.
 So as blow should be the solution:
 1. When you draw a new circle or import circles, save a special value in the column value of feature.
 2. When you edit a feature, find this value and see whether it should be a circle.
 Wish that’s helpful.
Hi Don,
 Would that be a proper solution, I doubt. Suppose I create a circle and save a value to identify it as a circle, but later edits the geometry to some other shape, wont it still show that it is a circle?
 Jacob
Hi Jacob,
 Why you want to change the circle to some other shapes? I meant if you don’t have this requirement you can disable other edit but only allow resize.
 If you drag anyone vertex of circle, it won’t be a circle but a polygon.
Hi Don,
 It was good to have the ability to change the shape if a circle, as it is now. Anyway since I have to avoid showing radius for other shapes I would better disable the editing of circles as you said. How do we do that and allow only resizing?
 Thanks in advance.
 Jacob
Hi Don,
I figured out that it could be done by setting
MapWindow.wpfMap1.EditOverlay.CanReshape = false;
Thanks and regards,
Jacob
Hi Jacob,
 I think the code is helpful.
  EllipseShape es = new EllipseShape(new PointShape(0, 0), 50);
            Map1.EditOverlay.EditShapesLayer.InternalFeatures.Add(new Feature(es));
            Map1.EditOverlay.CanRotate = false;
            Map1.EditOverlay.CanDrag = true;
            Map1.EditOverlay.CanResize = true;
            Map1.EditOverlay.CalculateAllControlPoints();
