Hii,
Can you provide a sample for showing mouse over-Tooltip for a point in wpf desktop 7.o maps.
Show Tooltip for point
Hi Latiya,
Thanks for your post, attached code is for your reference, Would you please check it?
Hope it helps
Summer
Post11569.txt (1.97 KB)
hii Summer,
Thanks for the code.
I made some progress.
1)lets assume i am adding a 1000 points using lat longs then how can i show the tooltip on mouse over.
by using GetDistanceFromDecimalDegrees i am getting a blinking tooltip as some points are clustered together.
If i decrease the distance then tooltip is not comming.
2)and also how can i select a feature of lat,long on mouseclick.
thanks again.
Hi Lalitya,
Considering your requirement, here is a better solution for you. Those codes are based on the sample “AddAnInMemoryMarkerOverlayplease” under HowDoI samples=>Markers. please check the attached code.
Please let us know if there is any thing confused.
post_11596.txt (2.37 KB)
Hi Summer,
Thanks fro the solution.Its working.
Hi Lalitya,
Great to hear it is sorted out, if you have any more question, please feel free to let us know.
Best Regards
Summer
